Author Topic: Salvaged R65 Winter built  (Read 45312 times)
Re: Salvaged R65 Winter built
« Reply #90 on: January 02, 2008, 02:14:43 PM »
Hi Jon,
I was going to suggest lifting the front motor mounts to above the down tubes.  This does a couple of things: Gives you more ground clearence in corners and gets the tranny/engine directly in line with the drive shaft which seems to help not wear out the universal joint.  The guys that road race airheads do this to get better handling/more cornering.
It looks that your latest incarnation of the frame has done this.  If not please consider it.  Now where is that Barber pic of the R65 I saw there....
« Reply #91 on: January 02, 2008, 03:26:55 PM »
Jon, any idea of what that bike weighs?
Jon_P
« Reply #92 on: January 02, 2008, 06:50:42 PM »
hey semper gumby have you been looking at my build plans? i am thinking about that, in fact i have a frame that i could take the right lower front mount from so i would have to try to cut down the left with the standard kick stand mount which i dont use anyways.
i havent weighted it yet but i know that the last set up was a lot lighter than stock. now mind you i am not the smallest guy and my wife says i look like the grape ape riding it but i can pick it up of the ground when it id upright. i can deadlift almost 550 lb. so i know it is less than that, that is as close as i can get right now. i do plan on taking it to a feed mill this spring and weight it when i'm done.
well a hour of cutting, drilling and grinding after work before the family got home and i got the other side done.
here is a shot from the rear
and no this isnt my disign for say, i am doing my version with the lower frame drop out like vanzen oldcro race frame. just wanted to say that so no one thinks i am taking credit for this disign.
Jon_P
« Reply #93 on: January 05, 2008, 06:16:47 PM »
work and a funeral slowed me down a bit this week. well i was able to get back on track aa little. i started with the swingarm fab today. i started with a hoop that ended up not matching the angular lines i had already so that went to the side adn made a new more angluar swingarm brace. here is what i ended up  with.
« Reply #94 on: January 05, 2008, 07:14:39 PM »
Call me when you need a test pilot.
Jon_P
« Reply #95 on: January 08, 2008, 07:32:30 PM »
sorry ed here is my test pilot ;D
this was done last summer, a friend of mine who is a photographer and he asked a bar maid he knew to add some beauty other than my ugly mug
« Reply #96 on: January 10, 2008, 09:56:01 AM »
Not sure if it is just me Jon, but I am not getting to the pickies from your last couple of posts...which is a pity
Steve H
« Reply #97 on: January 10, 2008, 10:17:01 AM »
Yes, Steve, it's quite a shame!  ;)
Jon_P
« Reply #98 on: January 13, 2008, 12:13:48 AM »
hit a snag, as my kids would say SNAP!
i was getting ready to pull everything down so i could do final welds. pulled the trans, it didnt just pop out but it did come out. the engine judt wouldnt come out. the new seat rails i put in where to low, so i had to remove them. cut a couple new pieces and put a bend in them so it would come up enough to enable the engine to be removed.
well now its off to final welds, then to the media blaster, then i dig out the powder coating gun.
Jon_P
« Reply #99 on: February 02, 2008, 08:07:54 PM »
well i havent been able to spend the time i needed on it the last couple of weeks. this week end i have been able to get started again. finalized how the swing arm is going to be done. i also didnt like the idea of just letting the final drive being held on by four bolts. so i made a mount to tie the final drive to the swing arm along with the normal mounting bolts.
i need to find a 14mm tap now for my uper shock mount. so i am getting closer to getting the mock up done.
« Last Edit: February 02, 2008, 09:14:37 PM by Jon_P »
« Reply #100 on: February 03, 2008, 10:54:46 AM »
Hmmm, just spotted your "test pilot" over on http://www.advrider.com/
Jon_P
« Reply #101 on: February 03, 2008, 02:24:52 PM »
jeff the photographer hangs out over there. i will have to go comb the site and see what he posted.
« Reply #102 on: February 03, 2008, 02:28:38 PM »
I guess I don't understand what you are trying to accomplish.  I originally thought you were building a cafe style and the latest pics looks like you are building a chopper and trying to come up with a sprung swingarm that at a glance looks kinda like a hard-tail?
Jon_P
« Reply #103 on: February 03, 2008, 02:34:56 PM »
i am going for a more of a retro boardtracker with some updated items. the seat will still be floating like i had it, and smaller tank, spoker rims.
my back cant do hardtails anymore, and building a frame with rear supension is my next challenge in building.
« Reply #104 on: February 03, 2008, 03:09:29 PM »
I was just curious as from a distance this will almost look like a hard-tail and you have the springer front end, fat front tire, etc...
