Author Topic: To introduct  (Read 2407 times)
Offline Sosyal
To introduct
« on: June 01, 2012, 09:37:54 AM »
Hi all,
being the newcomer, my first post is in Restoration Progress Logs with the topic "fuel injected R65". Then I realized that the introduction mails are posted here.
I'm living in Istanbul with my 82 R65, 93 R80 GSPD, 61 & 67 R60/2 and 72 CB750 K2. My favorite in the city is the R65 and yes you heard it correct: currently I'm in the process of converting "Uber" to fuel injection  :D
I'll post pre-conversion photos and the progress in time.
Cheers,
Ibrahim
« Last Edit: June 01, 2012, 09:39:57 AM by sosyal »
Cheers,
Ibrahim
Re: To introduct
« Reply #1 on: June 01, 2012, 11:42:04 AM »
Welcome aboard!
Fuel injection on an R65 sounds like a very interesting project - please keep us updated on your progress!
Re: To introduct
« Reply #2 on: June 01, 2012, 03:36:15 PM »
Welcome and yes i too want to see the result of this project.
dont think we have any other Turkish members have we ??
« Last Edit: June 01, 2012, 03:36:49 PM by Lucky_Lou »
Re: To introduct
« Reply #3 on: June 01, 2012, 07:48:07 PM »
Gorgeous bike!!!
But I've got to ask - why fuel inject it? What's to be gained?
Offline Sosyal
Re: To introduct
« Reply #4 on: June 11, 2012, 08:46:11 AM »
Sure, I will inform the phases of the project. And the answer to wirespokes is to see if I will succeed  :) I'm not looking for extra horsepower nor increase in torque but try to see if it can be done. Also, i will NOT change/modify the originals so that it can easily be converted to carburetors.
Ibrahim
Cheers,
Ibrahim
Offline Cano
Re: To introduct
« Reply #5 on: June 13, 2012, 10:27:39 AM »
What FI system are you using?  I'm running Megasquirt II on my 914.
Gordon
1982 r65ls
2012 Triumph Street Triple R
JPSpen
Re: To introduct
« Reply #6 on: June 13, 2012, 05:08:48 PM »
Welcome to the group...
Interesting project... Basic fuel injection is simple enough in itself..
You just need a handfull of sensors... I'm sure you know that...
Are you going to adapt a BMW FI system off a newer bike ?
Or, Go with a simpler aftermarket system that could be adapted to the BMW throttle bodies ?
Could be a fun thing to fool with.. But those Bings will go on forever...
Keep us posted...And get those 90's off the valve stems.. You don't want a valve stem to fail when you're riding down the road.. NO FUN..
DAMHIK....
John
« Last Edit: June 13, 2012, 05:12:06 PM by JPSpen »
Offline Sosyal
Re: To introduct
« Reply #7 on: June 19, 2012, 06:54:27 AM »
I'm not using any BMW or other FI system. We are making our Fuel Injection system (designing and producing the electronic board and software) with trial and error method. Does this explain why I'm late on answering your questions here?  :)
Now it's the time to design: to locate fuel pump, connect TPS, install a heat sensor to the body and an oxygen sensor to exhaust.
And about the valve stems, yes you are right. During my last trip on April through 600 km., they continuously lost air, a real PIA.
Cheers,
Ibrahim
Offline Sosyal
Re: To introduct
« Reply #8 on: March 19, 2013, 10:31:48 AM »
Hi all,
I've almost reached to the end of my project. Our custom designed and made fuel injection system (and computer program) is working now. We've designed the electronics board and received the board today.
Tonight, I will start installing the components and hopefully this weekend put the electronics on the bike and start the bike.
The only left work is paint the new gas tank (there has to be a fuel exit and fuel inlet, so the petcocks have been removed and nipples added), connect the fuel lines and check for a leak.
Later on I will start testing the bike and correct faults of the software, if any.
For the ones who want to follow up, I will update the progress @ Technical Discussion › Restoration Progress Logs › Fuel injected R65
Cheers,
Ibrahim
Cheers,
Ibrahim
