Author Topic: New 0ld Airhead - R60/5  (Read 7232 times)
Re: New 0ld Airhead - R60/5
« Reply #30 on: November 27, 2012, 07:19:21 PM »
What's the final drive ratio? I know some of them came with a 32/11 - pretty tall for a low displacement machine.
Look on the swing arm for the stamped drive ratio.  Some of the tall ratios like 32/11 were special order.  If I recall 32/10 was fairly stock.  the 32/9 were for sidecars.
« Reply #31 on: November 28, 2012, 03:04:54 AM »
As far as ratio's were concerned I had heard, years ago when I used to frequent the Boxerworks forum,  that the 4th gear in a 4 speed transmission was not that much different from 5th in a 5 speed transmission.
And it was the oppinion of some that the 5 speed transmission was an unnecessary bow to pressure for having the then fashionable '5 speed'...I.e. it was not really required, but since everybody else had one.....etc.  Not only that but the 4 speed was built from the outset with the kickstart in mind.  Whereas the 5 speed, the kickstart was an afterthought that was a good way of 'introducing iron filings to your trans fluid'.  Also the 5 speed kick start did not have the throw to really do the job of turning the engine over efficiently.
This is of course conjecture/hearsay on my part as I have never owned a 4 speed or a 5 speed with a kicker.
I have also heard that 4 speed kicker gearboxes are sought after, as there is the option of dropping the electric boot and all the weight that the bosch starter brings with it whilst still having the option of a reliable starter for the 'special' builder.
I feel that an R60 is a good buy, if you are looking for a bike with the period drum brake font end and spoked wheels, when compared to an R75/5.  You can still upgun it if you want and you will still save a sack of cash left over when comparing it to the price you will have to pay for a standard R75/5.  If you are not that hung up with the originality aspects.
Rev. Light
« Reply #32 on: November 28, 2012, 04:13:04 AM »
Both 4 and 5 speed boxes have the same overall gear reduction of 1:1.5 in top gear so comparisons with different final drive ratios are valid and the 4 speed bikes are not disadvantaged.
According to the period road test an R60/5 had a 3.36 final drive to give 14.9 mph/1000rpm in top. That'slightly taller than a typical R65 with a 3.44 final drive and what you would expect as the R60/5 makes it's maximum power at lower revs.
