Author Topic: after market shift linkage  (Read 11124 times)
Re: after market shift linkage
« Reply #15 on: April 30, 2010, 05:25:24 PM »
Melena has a 2nd generation R65 ('81-'84), so she should not have the "coat hanger" set-up that the early bikes had.  BMW upgraded in 1981 to a ball & socket connector, I believe.
Quite honestly, I never had a problem with mine, and it was with reluctance that I installed Justin's.
I like Justin's, but I believe the 1st gen. shift linkage could be fine on a one-owner bike that was babied (garaged) all it's life.
« Reply #16 on: April 30, 2010, 09:28:13 PM »
Melena has a 2nd generation R65 ('81-'84), so she should not have the "coat hanger" set-up that the early bikes had.BMW upgraded in 1981 to a ball & socket connector, I believe.
Ahhhh!  Thanks Rob.  I guess I'm fine with mine then.  It's kinda hard to see when it's 10 miles away.   :(  I'll check it out soon.  Didn't make it over there today.  Went for a walk around here instead.
« Reply #17 on: April 30, 2010, 09:30:59 PM »
The 81-84 shift linkages were definitely better than the coat hanger variety, but I can also tell you that they can also get sloppy/worn in a hurry too - especially with the disintergrating fiber washers they used with them..  Glad mine is sitting on a back shelf in the garage somewhere - I think that Justin's will last much longer.
« Reply #18 on: April 30, 2010, 09:38:56 PM »
Yes, I could see where those nylon parts would break down over decades, just like anything else.
With that in mind, I could see where a run might be feasible.
And perhaps Justin just doesn't have time for the extra work of posting the packages right now.
Someone else could put these things together?
Hey Melena - are you looking for a job?
« Last Edit: April 30, 2010, 09:39:31 PM by Rob_Valdez_79_R65 »
« Reply #19 on: April 30, 2010, 09:48:47 PM »
Perhaps  Rob Valdez Enterprises, a division of squirtworx....
« Reply #20 on: May 01, 2010, 08:07:26 AM »
The required Heim joints are available from these vendors. A short, DIY threaded rod, four nuts and two bolts - all 0.25" - you're good to go.
http://www.aircraftspruce.com/
http://www.wicksaircraft.com/
A fun Saturday project.  [smiley=thumbsup.gif]
« Reply #21 on: May 02, 2010, 04:44:06 PM »
Both the 82 and 83 LS's I owned had coat hanger wire shifts covered with that rubber boot accordion. I got the '83s replaced with Justin's and had it on in TN. when nhmaf helped me get it adjusted the right way. I had it all wrong I think as it was never tight. So I still carry a replacement coat hanger wire for others now but it doesn't take up any room at all.  I guess I just never took it off the bike even after the Justin design arrived. I did carry a spare coat hanger when the coat hanger was all I had on the bike. I bent one to fit after reading about a guy who replaced his on a trip by a visit to a hardware store. Gotta admit it is simple!! Just cheesy for a bike of such austere heritage!!
« Reply #22 on: May 02, 2010, 06:03:45 PM »
Those little clips and that rubber boot were anything but cheesy!
And this was the first design of the linked shift lever that really improved shifting performance!
I have always been proud of mine when I looked at those poor, old airheads with their shift lever mounted directly onto the shift shaft...
Patrick_Krivacka
« Reply #23 on: May 02, 2010, 08:16:16 PM »
i guess i should back off on calling the coat hanger cheesy. Like i said, I think mine was messed with (bent) by the PO as some kind of adjustment. I'd be interested to try one without it having been bent.
i still have the one Rob was nice enough to send me, and i promise to send it on to the next person who needs it.
« Reply #24 on: May 04, 2010, 08:01:11 AM »
You and me both I-man. Rob is right....especially the rubber boot is very nice and that is the one thing I missed on the bike when I replaced the wire one. Those clips were pretty inspired too and after I actually zip-tied the one clip on that only once tended to slip, it never had another problem. I bet the rubber boot setup helped me get a prize at the concours during our vintage rally.
« Reply #25 on: May 04, 2010, 05:32:43 PM »
But those rubber boots have a short life-span, if they are removed too many times, I will quickly admit.
« Reply #26 on: May 04, 2010, 10:38:28 PM »
I seriously believe the factory used the boot to hide the cheesey coathanger wire out of embarrassment!
If a few people want linkages I'll order some joints but I don't sell enough of them anymore to warrant stocking a bunch of parts I'll probably loose before I get around to building something!
PM me if you need/want one...
aussie
« Reply #27 on: May 06, 2010, 05:27:41 AM »
Justin. If you're going to do another order, I'd be interested in one - let me know and I'll pay.
fermin
« Reply #28 on: May 19, 2010, 04:07:16 PM »
Justin
Count me in for a linkage.  Do you have enough orders yet?
« Reply #29 on: May 19, 2010, 04:29:55 PM »
In anticipation of adding another airhead to my stable and in the interest of bolstering the order, I would take one, also.
