Author Topic: Heated glove power use  (Read 3217 times)
stockman
Re: Heated glove power use
« Reply #15 on: November 05, 2010, 05:22:31 PM »
Ok it's the weekend and I will try it. I use picassa and if uploading it resized them, thanks to all.
Darwin_R65
« Reply #16 on: November 13, 2010, 08:17:36 PM »
If you want a simple application for resizing pictures I use picturetray.
you can do one or many at the same time, and it's all drag and drop.
FREE program.
http://www.picturetray.com/default.asp
John
stockman
« Reply #17 on: December 03, 2010, 07:58:38 PM »
12/3/10 still riding thanks to the Gerbings gloves. I've got the routing of the cables down to a science now. I utilized some medical use clamps used to hold feeding tubes connectors(AMT Clamp) together to keep the on off switch connected to the cable coming from my jacket . But I think the snow will be here soon.
Offline R65Guy
  • I'd rather be ridin'
« Reply #18 on: December 05, 2010, 12:42:45 PM »
I have a Tourmaster liner @ 76 watts and Gerbings T5 gloves @ 27 watts.  103 watts at 100% power, 100% of the time.  A newer electronic controller on low means you are probably only drawing ~34 watts continuous.  I would not worry too much about using them on the R65.  Keep the revs up and should be no problem.  In fact I have wired my Kubota tractor so I can plug in while pushing snow.... and the R65 alternator puts out probably 3 times the wattage (280) as my Kubota!
P.S. Rode my GS 230 miles yesterday in 35-40 degree temps with 30 mph gusting cross winds and I doubt I ever had my controller over 50%.  No worries.  Go ride and enjoy, put it back on the battery tender when you come home.
81 R65 & 16 R1200GS
stockman
« Reply #19 on: December 11, 2010, 08:08:41 PM »
FYI the gloves are great even without the elec. On, the membrane inside does a good job of blocking wind. This past work week we had some days here in NH where the temp at 7:15 am was in the 20's so it was my first week using the truck to go to work . I want to get some more heated clothing I think a vest or jacket liner next. I've had no issues with the electrical system and the gloves power consumption.
Snow is coming any day now.
