Author Topic: Tool Time  (Read 850 times)
Tool Time
« on: July 01, 2008, 08:51:36 AM »
Common Tools and Their Useage
DRILL PRESS  A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly stained heirloom piece you were drying.
WIRE WHEEL  Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Yeoww Sh#@!"
ELECTRIC HAND DRILL  Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW  A portable cutting tool used to make studs too short.
PLIERS  Used to round off bolt heads. Sometimes used in the creation of blood-blisters. The tool most often used by women.
BELT SANDER  An electric sanding tool commonly used to convert minor touchup jobs into major refinishing jobs.
HACKSAW  One of a family of cutting tools built on the Ouija Board principle. It transforms human energy into a crooked, unpredictable motion and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS  Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES  Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH  Used almost entirely for ligniting various flammable objects in your shop. Also handy for lighting up the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS  Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or ? inch socket which you've been searching for the last 45 minutes.
TABLE SAW  A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK  Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2x4  Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS  A tool for removing wood splinters and wire wheel wires from your fingers and body.
E-Z OUT BOLT & STUD EXTRACTOR  A tool ten times harder than any known drill bit that snaps off neatly in bolt holes, thereby ending any possible future use.
RADIAL ARM SAW  A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST  A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-Inch SCREWDRIVER  A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS  See Hacksaw.
TROUBLE LIGHT  The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, the sunshine vitamin, which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER  Normally used to stab the vacuum seals under lids, opening old-style paper and tin oil cans and splashing oil on your shirt. Can also be used, as the name implies, to strip out Phillips screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER  A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR  A machine that takes energy produced in a coal-burning power plant two-hundred miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford and instantly rounds off their heads. Also used to quickly snap off lug nuts.
FLASHLIGHT  Cylindrical object used to store dead batteries.
PRY BAR  A tool used to crumple the metal surrounding that clip or bracket you need to remove in order to replace a 50 cent part.
HOSE CUTTER  A tool used to make hoses too short.
HAMMER  Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Women primarily use it to make holes in walls while hanging pictures.
CARPET KNIFE  Used to open and slice through the contents of cardboard cartons delivered to your front door. Works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks and rubber or plastic parts. Especially useful for slicing work clothes, but only while being worn.
DAMMIT TOOL  Any handy tool that you grab and throw across the garage while yelling, "DAMMIT", at the top of your lungs. It’s also, most often, the tool that you will need next.
Re: Tool Time
« Reply #1 on: July 01, 2008, 11:25:37 PM »
I've seen this one before.  It always gives me a good laugh!   Especially that last one!  [smiley=ROTFLMAO.gif]
