Author Topic: iTOTAL electrical failure  (Read 3442 times)
vestandpants
Re: iTOTAL electrical failure
« Reply #15 on: January 11, 2008, 09:42:15 AM »
i couldnt aggree more Justin.  :D corrosion is part of my life, in fact i would be lost if there was no rust to wire brush or iron oxide to sweep up from under the vehicles i own  ;)
« Reply #16 on: January 11, 2008, 02:22:05 PM »
Can and ordinary person obtain one of them thar TDR's at a reasonable price??? They sound just the ticket!!!
« Reply #17 on: January 11, 2008, 04:59:13 PM »
When I was in field service the office I worked out of had a "cheapie" hand-held unit and I seem to remember it was around $2k, but that was a long time ago.  I really don't know how useful one would be on a wiring harness with max lengths as short as ours...  I think the way they work is to send out an RF pulse and time how long it takes to get a reflection and how the reflection was modified.
Offline donbmw
« Reply #18 on: January 11, 2008, 06:03:04 PM »
Go to Eastwoodco.com they have 2 items one is call fault finder and the other is Short Circuit Tester. I have seen the fault finder work.
Don
Chris_in_BC
« Reply #19 on: January 11, 2008, 07:23:02 PM »
Hi John,
   I have had the ignition switch fail.  See if you can reach the bottom of it. Have it turned on, then apply pressure to the base where the wires connect (maybe get a wooden dowel in there (not anything metal)) See if lights come on once you are applying pressure.
In my case, once I ascertained it was the switch I removed it and tightened up the base to the key part. Amazing those zip ties have lasted the last 8 years.  ;)
Chris
« Reply #20 on: January 12, 2008, 11:40:10 AM »
a TDR [time domain reflexometer] is meant for telephony / data type twisted pair or coaxial wiring. Its operation depends on circuit capacitance, wire gauge as a function of resistance and some other special voo-doo like cable core insulation, line impeadance and sheathing. I would be great if they worked on cycle / automotive wiring but alas... The best bet is still a working knowledge of the use of a volt / ohm meter and knowing how to read a wiring schematic. Besides there really is no such thing as electricty. Its all done with magic smoke. Ever work on somthin' 'lectric and have smoke come out of it? It stoped workin' didn't it!
who may or may not have a few TDRs in his tool box.
« Reply #21 on: January 16, 2008, 06:41:14 PM »
John,
Any progress, questions?
megrimsrex
« Reply #22 on: January 30, 2008, 04:58:13 PM »
well i finally got the got the switch off, it was exteamly difficult it requires some sort of special tool that i dont know about. it is very badly rusted. im gonna polish it up and try to get it to work. no progress yet. thanks guys
