Author Topic: Rebuilding Master Cylinder  (Read 2244 times)
Offline MikeFossl
« on: September 11, 2020, 10:13:32 AM »
Any gotcha’s?   Is there a step by step somewhere on the forum?
Thanks!
1985 R65
Offline dogshome
Re: Rebuilding Master Cylinder
« Reply #2 on: September 11, 2020, 02:03:49 PM »
Very easy job. I would add that putting a micro drill or other very fine wire through the return bleed port is a good idea. A sewing pin is too large. Also to lubricate the dry side where the circlip is with brake friendly grease. The stuff that comes with caliper rebuild kits. That area suffers corrosion.
If you keep the fluid in the lines, bleeding should be fairly easy. You will see bubbles rise from the bleed hole with the reservoir cap off.
Offline BPT
« Reply #3 on: September 12, 2020, 07:33:12 PM »
Would that be the recommended way (easiest and most efficient) to bleed the brakes? I've always had help in the past but need to do it solo.  Seems there's almost as many opinions on how to do that as there are oil posts on Airhead forums.
I've heard good and bad about using a device or not,  top to bottom or  vice versa, etc., etc.  One of those questions I'd been wanting to  ask but have put it off.  Not sure why I dread brake bleeding, but I do.......
Offline wilcom
« Reply #4 on: September 12, 2020, 08:55:55 PM »
Because it is a PITA ;D that's why. I've done it top to bottom and bottom to to-top used a vacuum pump. I just go back to the ol fashion way. The MC is so small it takes forever to bleed them, just stick with it and make sure that lil return hole is free and clean, the one you use the piece of small wire to poke thru. I had mine bled and a hard grip in about 10 minutes the last time I did mine. I have also cussed them for an hour to get the same job done. I haven't a clue as to what I'm doing differently when I have success?
Good Luck
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline BPT
« Reply #5 on: September 12, 2020, 09:46:52 PM »
Haha, thanks, I don't feel so bad now. I thought i must be missing some small thing or just never had that "A-Ha!" moment where it all became clear.  I guess I'll try it the basic way like in your video link, and hope for good luck.
Offline dogshome
« Reply #6 on: September 13, 2020, 02:10:26 PM »
Mine was fine, just patience. Do one side, then the other and be prepared to do the first then second sides again. A clear bleed hole makes the difference,
Offline BPT
« Reply #7 on: September 14, 2020, 01:36:14 AM »
Well I only have a single disc so at least it'll only suck half as much ??
« Reply #8 on: September 14, 2020, 10:04:40 AM »
If it's only a routine fluid change then the easiest fool proof way is to gravity bleed.  Just attached a short length of tube, open the bleed nipple and let it drip into a jar.  As long as the reservoir is kept topped up it's impossible to introduce air. No fuss and a solid brake lever every time.
Offline BPT
« Reply #9 on: September 15, 2020, 04:11:21 PM »
Thanks Barry.  I need to do it soon so I'll give that simple method a shot.  Maybe the stars will be aligned correctly and it'll work for me.
        Thanks
Offline skippyc
« Reply #10 on: September 15, 2020, 05:51:44 PM »
I have 2 cheap one way valves with pipe on each end. I can plug them on to the bleader valves and pump the fluid through. takes no time at all.
I think the valve were fuel valve, ebay specials.
