Author Topic: For those looking for JPT connectors  (Read 3262 times)
Offline ged in oz
Re: For those looking for JPT connectors
« Reply #15 on: August 01, 2019, 03:22:03 AM »
Received my order today
They appear to be of good quality and are compatible with the OEM connectors
Will those Meterk style crimpers that you posted above work ok on that connector MrC?
Offline BPT
« Reply #16 on: August 01, 2019, 01:27:46 PM »
I don't know about that specific tool but these connectors usually require an "open barrel" die.  Sometimes called an "F" (not to be confused with "F Type" which is some kind of co-ax connection).
The other thing to make sure of (if MrClubike can't give you the specifics) is that the one you get will do the right size wire your using.  The bean can wiring gauge is pretty small and I've seen that some of the crimpers will stop at the next thicker gauge.
