Author Topic: Won't turn past bottom dead center ('83 R65 w/860)  (Read 4260 times)
Re: Won't turn past bottom dead center ('83 R65 w/860)
« Reply #15 on: June 05, 2019, 07:51:53 PM »
FYI
Auto Zone had the triple square bit needed to remove the connecting rod bolts in stock at the store near me
So if you need  it their is a chance you can get it
They only had it in the set
Offline Sejati
  • 1982 R65LS
« Reply #16 on: June 19, 2019, 09:54:32 AM »
Both pistons came in (with rings and gudgeon pin) at 576g.
And this is my block after some filing. Gonna do a testfit tomorrow.
And that docx is the warning that should have been included with the kit.
Any update with your piston installation?
