Author Topic: Bolts for clutch removal tool  (Read 5017 times)
Offline John M
Re: Bolts for clutch removal tool
« Reply #15 on: February 02, 2019, 03:17:05 PM »
Also purchase a new throughout bearing for the clutch pushrod  . Examine the pushrod for any scarring and if it looks good just polish it with crocus cloth
Offline John M
« Reply #16 on: February 02, 2019, 03:18:06 PM »
Also purchase a new throughout bearing for the clutch pushrod  . Examine the pushrod for any scarring and if it looks good just polish it with crocus cloth.
Offline John M
« Reply #17 on: February 02, 2019, 03:41:34 PM »
Check out Motobins, for any clutch pushrod and related parts .They are very good to deal with .  My memory re all of the parts in the clutch pushrod assembly is 8 years old and not reliable as that was the last time I had one of mine apart ..Talk to Damien at Motobins ,he is very good.
Offline Soeren
« Reply #18 on: February 03, 2019, 12:44:33 PM »
Thanks John. Im very familiar with motobins, I'v gotten quit a lot of stuff from them over the years.
Just to be 100% sure before I start ripping out seals.
This is the clutch pushrod oil seal right?
https://photos.app.goo.gl/rv5EzZDNjZFp3xLk8
No. 15 in this blowup.
And, I cant seem to get the clutch assmebly off. All 6 bolts are out, I tryed heating it a little, and give af few gental taps with a hammer, but it wont budge.
« Last Edit: February 03, 2019, 12:52:08 PM by Soeren »
'83 BMW R65
Offline John M
« Reply #19 on: February 03, 2019, 03:14:18 PM »
#15 is not a seal that is the inner race of the pushrod bearing
« Reply #20 on: February 03, 2019, 08:14:25 PM »
When I removed the transmission I noticed a smalle rubber ring and a spring seal tangled together next to where the clutch control enters the transmission.
I tryed to identify it in the realoem parts fiche, but can't find it.
What is it, and has more of it dropped into the transmission?
i think this the seal you are looking for
« Last Edit: February 03, 2019, 08:16:48 PM by Mrclubike »
Offline John M
« Reply #21 on: February 04, 2019, 03:13:33 AM »
that seal is at the opposite end of the transmission (front).
« Reply #22 on: February 04, 2019, 08:20:58 PM »
This is the seal at the front of the input shaft on the  OD
Offline Soeren
« Reply #23 on: February 05, 2019, 02:19:18 PM »
Yes this is it, after I wiped it down I found a tear in the lip and I want to replace it. How do I best go about getting it out, can I get it out with a pick tool?
I have a set of these:
'83 BMW R65
« Reply #24 on: February 05, 2019, 05:10:31 PM »
Most people use a suitably sized screw driver and (maybe) a rubber mallet to remove small seals. Learger seals are usually easily removed by running self tapping screws partially in around the periphery and then using a screwdriver or a claw hammer to lever them out using the screw heads.
To put seals in, a socket of about the same size and a rubber mallet usually works. But for big seals (for example the rear main seal) a proper tool is advised.
If you are a person that must have the "correct" tool, these are good examples of ways to spend money:
 https://www.ebay.com.au/itm/10-Pcs-Bearing-Race-Seal-Driver-Installer-Set-Remover-Automotive/301768118014?hash=item4642c80efe:g:6lIAAOSwc49Y6HQy:rk:1:pf:0
https://www.ebay.com.au/itm/12-Rubber-Seal-Puller-Remover-Oil-Grease-O-Ring-Grommet-Removal-Pulling-Hook/263570240885?epid=2218287641&hash=item3d5e02b575:rk:4:pf:0
PS - for my sins I own both of the above.
This one however is money well spent:
https://www.cycleworks.net/index.php?main_page=product_info&products_id=18
It will also set the big seal in the final drive.
