Author Topic: How to center the clutch plate  (Read 2698 times)
Offline Jschara
« on: November 04, 2018, 10:33:42 AM »
Can anyone let me know their technique for centering the clutch plate on a 1979 R65.  I have seen a tool for /5, /6 and K bikes but haven't come across one for the R65.
Jim
Re: How to center the clutch plate
« Reply #1 on: November 04, 2018, 11:31:16 AM »
I have the later clutch carrier, I don't know if this will work on the earlier bikes.
I install the clutch plate and the rear plate, I can't remember if it's the pressure ring or plate .
Before I tighten the bolts. I measure the distance from the clutch plate to the edge of the rear plate, get as close as possible to even all the way around .
Put the transmission on and install all the fasteners but don't tighten them up all the way leave it a few threads before it tightens up, insert the clutch rod through the transmission until it stops .
I rotate the output of the transmission and either push on the clutch rod, or use a rubber mallet to hit the rod, you don't need a lot of force .
Hasn't failed me yet .
« Last Edit: November 04, 2018, 11:32:51 AM by Bob_Roller »
« Reply #2 on: November 04, 2018, 02:55:01 PM »
Jim
You are looking for a tool for pre-1981 airheads. I don't think there is any difference right back to the R50/R75 inception, but if you look for a tool that will fit a stroke 7 R100/R80 then it will fit the R65.
Alternatively you can use a dial gauge to center the plate, but I'm here to tell you that is slow and tedious.
Code: 99350 at Motobins for GBP13.00 and it would appear I'm right, the same tool fits virtually all pre-1981  bikes.
Offline donbmw
« Reply #3 on: November 04, 2018, 04:02:39 PM »
It it the same clutch alignment tool that I use on my 79 R 90/6 and my 82 R 65
Offline skippyc
« Reply #4 on: November 04, 2018, 04:24:04 PM »
Never looked at a R65 clutch, but i turned up a centering tool out of wood on my metal lathe to do my ford cortina clutch and it worked well.
« Reply #5 on: November 04, 2018, 05:14:20 PM »
That would work a treat!
« Reply #6 on: November 05, 2018, 03:32:20 AM »
I used a PVC pipe of the same diameter as the hole. Glued a bit of plastic to close the front, and drilled a hole in the center for the clutch actuation rod. The bit of plastic was from the cap of a jug...
The longest part was to find the correct plastic parts and glue them...
Can't post a pict as I've unfortunately binned the tool in a tidying crisis...
Offline skippyc
« Reply #7 on: November 05, 2018, 04:11:12 PM »
Isn't that a problem when cleaning up, it's why i try to avoid doing it.
« Reply #8 on: November 07, 2018, 01:23:59 PM »
I was looking at the Euro Motoelectrics site today and came across this clutch alignment tool for early  R65''s .
https://www.euromotoelectrics.com/product-p/clutchtool-ahearly.htm
Here's one for '81 and later year  bikes .
https://www.euromotoelectrics.com/product-p/clutchtool-ahlate.htm
« Last Edit: November 07, 2018, 01:27:58 PM by Bob_Roller »
Offline Jschara
« Reply #9 on: November 07, 2018, 04:44:36 PM »
Thanks to all who replied to my question.
Bob-Rooler, I ordered the tool from EME.
Jim
