Author Topic: Leaking Master Cylinder  (Read 4008 times)
Offline TomHoldom
Re: Leaking Master Cylinder
« Reply #15 on: September 22, 2018, 10:34:50 AM »
Sorry, Barry I hadn't seen your reply.
So it looks like you're right - the brass inserts have decided to come loose from their housing - thought it was a bit odd that 2 of the screws could have snapped without me noticing - you think it might come off just by pulling? (obviously bit nervous about trashing it, as I don't believe the circular ones are replaceable
Offline TomHoldom
« Reply #16 on: September 22, 2018, 10:49:36 AM »
yep barry you're right - the inserts must be turning.
Any ideas ?
« Reply #17 on: September 22, 2018, 01:19:06 PM »
Well I know that if you use screws that are too long the inserts jack out  and that's when the inserts have a good hold and are not spinning. I think if you prise the cover upwards with care The cap, inserts and all will come out easily enough. You could then grip the inserts lightly in a vice and try to remove the screws.
« Reply #18 on: September 25, 2018, 10:43:28 PM »
[split] [link=http://www.bmwr65.org/YaBB2.612/cgi-bin/yabb2/YaBB.pl?num=1537807147/0#0][splithere][/link][splithere_end]
Thread was diverging wildly from original ancient post so I gave it a life of it's own...
« Last Edit: September 25, 2018, 10:45:33 PM by admin »
