Author Topic: Neutral switch problem R65  (Read 4775 times)
Re: Neutral switch problem R65
« Reply #15 on: June 06, 2018, 09:26:38 PM »
Well look on the bright side.
The boik will have fresh Honda moly on the transmission splines, new boot on the drive shaft, fresh grease on the swing arm bearings, and fresh valvolene 80w90 (white bottle) in the trannie, drive shaft and final drive, fresh grease on the wheel splines (after they are cleaned) when he’s done.
With all that done you can drive to hell and back or fifteen thousand miles which ever comes first, with impunity!   ;D
« Reply #16 on: June 07, 2018, 01:25:11 AM »
Before opening it up, are you SURE you have the OEM very thick washer in place ? (about, if my memory serves me right, 7 to 10 mm high)
« Reply #17 on: June 07, 2018, 04:22:48 AM »
i hate to be the harbinger of doom, but it was working and now it isn't.
