Author Topic: Bar replacement  (Read 3892 times)
Offline roadkill
Bar replacement
« on: May 25, 2018, 06:50:44 PM »
Trying to put my 82 r65 back to mostly stock configuration after a previous owner had "improved" it.  PO changed the bars to a short low bar that won't allow the dash pad to fit properly.  Where would I find an aftermarket bar that is most like the OEM. Or, if someone has a nice original, I might be interested.
Also need the bulb assemblies for turn signals. When he threw away the original dash pad, he chucked the in-dash signal lamps as well.  What might be a good source for those?
Offline wilcom
Re: Bar replacement
« Reply #1 on: May 25, 2018, 08:30:52 PM »
Roadkill.........
Take some pictures of your bike so we will have a visual and will be better able to guide you. Next, go to WWW.realoem.com and look up your bike and find the part numbers of the stock pieces you are needing.  Pictures first, let us "see" what you need.
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Re: Bar replacement
« Reply #2 on: May 25, 2018, 09:44:53 PM »
Motobins
and
Motoworks
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=20&Ct=OA&SbCt=BA_15_20_OA_20
« Last Edit: May 25, 2018, 09:57:50 PM by Mrclubike »
Re: Bar replacement
« Reply #3 on: May 25, 2018, 10:09:16 PM »
I put RT bars on mine and I had to drill a hole in the dash pad to prevent the clutch cable from kinking
They are taller than the original bars
« Last Edit: May 25, 2018, 10:14:50 PM by Mrclubike »
Re: Bar replacement
« Reply #4 on: May 25, 2018, 10:13:59 PM »
Are you looking for these
Moto Works and Motobins has them
Offline roadkill
Re: Bar replacement
« Reply #5 on: May 26, 2018, 07:50:54 AM »
Looking for the lamps (bulbs) and the sockets with wire. My lenses are ok.
Offline roadkill
Re: Bar replacement
« Reply #6 on: May 26, 2018, 07:58:07 AM »
Pics of what going on.  Bars are not as wide as OEM, pic 1 and 2 show what I have.  Pic 3 is what I'm looking for.  (Hope the pics show up) :-[
« Last Edit: November 09, 2020, 05:15:42 PM by Justin B. »
Offline wilcom
Re: Bar replacement
« Reply #7 on: May 26, 2018, 10:11:54 AM »
Thanks for the pics Roadkill. Check to see if there is a part number on the short bars to give us an idea what they were for(maybe your bike?)
When I fitted my short bars I put on the dash pad and left the bars and controls lose and adjusted with the tilt of the bars and the tilt of the controls since the dash pad is immobile and everything else will move.
I'm sure there are folks on the East Coast but I use Stoners Beemer Stash here on the West Coast for odds and ends. I just got the original bars for my LS from him along with a couple of other onesy twosy items.
Stoner's Beemer Stash
Larry Stonestreet       39628 Avenida Miguel Oeste
Murrieta, CA 92563
(951) 813-1704
ca.stoner@yahoo.com
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Re: Bar replacement
« Reply #8 on: May 26, 2018, 11:09:15 AM »
I have gotten Part from this guy on eBay
You can send a message to him and see if he has them
https://www.ebay.com/usr/reclaimbmws?_trksid=p2060353.m2749.l2754
Re: Bar replacement
« Reply #9 on: May 26, 2018, 01:00:21 PM »
If I'm not mistaken, the bulb holders are still available new from BMW and surely from the Brits.
The bulbs are 3 to 5 W T bulbs as used on cars.
But the bulb holders have flat spades for AMP style spade on the wires... So you may have to "rewire" a bit...
The OEM wiring loom is still available new from BMW. Last time I looked it was around 160 € plus shipping.... So ....
For the bars, I would ask a place like Motorworks for a decent used one.
Offline jp9094
Re: Bar replacement
« Reply #10 on: May 26, 2018, 03:43:17 PM »
I'm afraid, the bulb holders are no longer available s I tried to source them a while back. They hold 12 volt 194/BP2 bulbs. They have bendable wire loops that make the contact with the bulb holders. Problem with mine were they were stretched and when I tried to tighten them, the broke (or at least 2 diametrically opposed contacts did). I solved the problem by bending one loop over to the other side so they made the appropriate contact. By the way, if you find a source for them, please let us know!
Thanks in advance.
Re: Bar replacement
« Reply #11 on: May 26, 2018, 04:10:49 PM »
Well, Motorworks has them, new :
Instrument bulb holder | INA81725
Offline roadkill
Re: Bar replacement
« Reply #12 on: May 26, 2018, 04:50:08 PM »
Thanks for the replys.  I've contacted a few vendors. I'll post on this forum asking if anyone has a decent set of stock bars.
Offline roadkill
Re: Bar replacement
« Reply #13 on: May 26, 2018, 07:17:45 PM »
It seems INR 44626 is listed for 80 to 85 R65.  No longer available from BMW, but they may have some.  "Stock of this item varies, check for availability and condition".  These is a used item.
Offline donbmw
Re: Bar replacement
« Reply #14 on: May 26, 2018, 07:52:25 PM »
I have a Don Vesco Rapid Transit fairing on my 82R65. I put the sport bars on that came with the fairing I had the same amount of rise as your picture shows and hand no problem installing the dash. Looking at your picture the bar clamps need to be loosened and rotated back. I now have RS bars installed still with the stock dash installed
Don
