Author Topic: Wiring Harness Question - 1979 R65 - US Spec  (Read 6508 times)
Re: Wiring Harness Question - 1979 R65 - US Spec
« Reply #15 on: December 29, 2017, 05:50:15 PM »
Make sure you get the Blue exciter wire hooked up correctly
If you don't the alt may not charge or you could have a parasitic drain
Offline Eric65123
« Reply #16 on: December 31, 2017, 03:13:37 AM »
Mrclubike, now that makes sense. I know that the negatives are the brown wires grounded. But didn't think that negative wire on the coil changes +-+-!! Thanks for that. :)
Yes so I got that black wire from the coil connected to the RPM wire of the gauge. Managed it to work but comes on and off intermittently. Grounding? Gauge fault? I hope I haven't buggered the gauge yet.
Got those blue exciter (D+) connected properly, charging is good. I had that resistor tapped in as well.
« Reply #17 on: January 02, 2018, 04:54:37 PM »
Just to make sure, your bike does not have the factory 4-way flashers, does it?
That diode looks like the one that comes with it.  It would have been located in the fuse/relay box under the right-hand side cover.
Offline Eric65123
« Reply #18 on: January 05, 2018, 05:42:47 AM »
Thanks Rob. Got this sorted. Yes I have the 4 way flashers.
I also got the RPM working now with the same signal wire except, having to add a capacitor 100nF to the black rpm signal line and grounded resistor 150Kohms tapped after the capacitor to the same rpm signal wire.
« Reply #19 on: January 05, 2018, 05:33:28 PM »
If you want some information on the 4-way flasher, I have photos and the installation manual on my hard drive at home.
Offline BPT
« Reply #20 on: January 05, 2018, 05:48:47 PM »
I'd be interested in that, Rob.
« Reply #21 on: January 05, 2018, 08:16:01 PM »
here is the later R65 flasher print
« Reply #22 on: January 05, 2018, 08:20:21 PM »
here is another one /7 maybe
from snowbum
« Reply #23 on: January 05, 2018, 08:33:17 PM »
Neither of them are  easy to understand :o
The reason they are so complicated is
They have a latching relay that keeps the flasher going even after the key is turned off but cant be turned on unless the key is on
If you remove this feature they are very basic
« Reply #24 on: January 05, 2018, 08:50:03 PM »
This kit fits the 81 thru 84 models also
It is what I used on mine
Offline BPT
« Reply #25 on: January 06, 2018, 04:22:44 PM »
Thanks, MrClu.  I got the kit quote a while ago but put it at the bottom of the list of projects.  This post reminded me I still need to install that.
Thanks for the pics.
« Reply #26 on: January 06, 2018, 04:44:54 PM »
Remember that the red cover for the R65 hazard switch is still available from your dealer. And the triangle in the correct way is very nice...
