Author Topic: Who is running with LED H4 conversion bulb?  (Read 3938 times)
Re: Who is running with LED H4 conversion bulb?
« Reply #15 on: June 06, 2017, 10:09:14 PM »
My idea is to be seen during the day and see at night  while using less power  ;)
« Reply #16 on: June 14, 2017, 08:12:56 AM »
I installed  Truck-lite in my BSA's.  unfortunately this 7" headlamp will not fit in the slightly smaller R65 headlamp.
The trucklites are a miracle on the BSA.  They do not care about polarity and the view down the center of the road is brilliant.  Plus I am seeing the deer starting at 25 degrees left and right.
I think I bought the 70c for the two BSAs.
http://www.truck-lite.com/webapp/wcs/stores/servlet/CategoryDisplay?urlRequestType=Base&catalogId=10002&categoryId=13091&pageView=grid&urlLangId=-1&beginIndex=0&langId=-1&top_category=15554&parent_category_rn=13089&storeId=10001#facet:-70000000000000032865534&productBeginIndex:0&orderBy:&pageView:grid&minPrice:&maxPrice:&pageSize:&
The only down side of the Trucklite is the plastic lense seems soft and easily scratchable.  So I intend to get the 3m protective film from Tourtech or Twisted Throttle for the two lamps have on the 71 THunderbolt and the 69 Rocket 3.
I wish they made a 6-volt version.  :-/
« Last Edit: June 14, 2017, 08:18:49 AM by Semper_Gumby »
