Author Topic: Question on Valves/Compression Stroke  (Read 3270 times)
Offline jamestnewsonr65
Re: Question on Valves/Compression Stroke
« Reply #15 on: April 18, 2017, 04:15:12 AM »
Someone on here (Montmill I think), mentioned that a few dabs of white paint on the timing marks helps with the visibility if you have the gearbox off at any point.
1981 R65 (box of bits).
« Reply #16 on: April 18, 2017, 09:37:14 AM »
Actually, you can mark the timing spot without opening anything except removing the rubber button.
Use either a white pencil from art store or Tippex on it's small paint brush.
Perfect for the job and no excuse for waiting ...
Offline Lordcargo
« Reply #17 on: April 24, 2017, 04:26:45 PM »
I did set my valves and thanks to all above. Several helpful hints, especially  the old thumb in the spark plug hole.
2013 Goldwing F6BD
Offline Billmc
« Reply #18 on: May 26, 2017, 09:53:52 AM »
Did mine this past weekend:
Jacked up the bike with my new Harbor Freight Motorcycle Jack, which put it at a comfortable level for this weak back of mine. Popped the covers off,(after popping open a Schiner Bach) pulled the plugs, stuck in a straw and rotated the back wheel while in 5th gear.
WAAAAY easier than laying on your back in the dirt during a HOT Texas summer afternoon adjusting VW valves....  ;)
1987 R65 Silver
