Author Topic: Replacement Diode Board (Ei)  (Read 2322 times)
Offline jamestnewsonr65
« on: February 03, 2017, 08:34:07 AM »
Quick question which I am hoping will be a very simple yes / no.
I have a new diode board from Emerald Island which is designed to provide a better charging flow.
Does this need to be installed as part of an alternator upgrade also, or can it be installed on it's own?
1981 R65 (box of bits).
Re: Replacement Diode Board (Ei)
« Reply #1 on: February 03, 2017, 09:01:33 AM »
Yes, it can be installed without replacing any other components in the charging system .
Remove the battery cables before removing tbe diode board, there is a red wire that goes from the diode board to the battery, it's got power all the time .
« Last Edit: February 03, 2017, 09:05:34 AM by Bob_Roller »
« Reply #2 on: February 03, 2017, 10:46:00 AM »
I thought that it may be able to be replaced on it's own but also thought it was best to ask.
Thanks Bob.
« Reply #3 on: February 04, 2017, 06:05:51 PM »
« Reply #4 on: February 04, 2017, 08:15:26 PM »
Or you can build your own out of Delco 10SI parts
« Last Edit: February 04, 2017, 08:15:49 PM by Mrclubike »
« Reply #5 on: February 05, 2017, 04:13:13 AM »
Nice job and if it was ever to go wrong you'd be able to fix it.
« Reply #6 on: February 05, 2017, 04:53:55 AM »
@bob_roller yes one of those types. Thanks for that's link I think helps having the wiring diagram.
« Reply #7 on: February 05, 2017, 04:14:07 PM »
So I tried to fit this today and it does not seem to tighten up and not move on the mounts. There is a bit of play when installed. Is this supposed to be used with the solid mounting kits?
Any info appreciated
« Reply #8 on: February 05, 2017, 04:27:22 PM »
The board should not be loose when the fasteners are tightened .
Have the fasteners gotten tight and the board is not being held by them ??
« Reply #9 on: February 05, 2017, 04:51:19 PM »
Yes that's what seems to be happening. One thing it might be is that I think the ground bolts on the back might be fouling the case somehow. I'll have another look this week, when I get a chance.
« Reply #10 on: February 07, 2017, 08:38:19 AM »
Looks like the original bolts are too long to fix the new board up tight as the original had a thicker body.
I just used 5 washers on each of the bolts to make this fit fully in position.
