Author Topic: Rear wiring harness connector  (Read 1076 times)
Offline black pearl
« on: December 01, 2016, 08:32:31 PM »
Can anyone advise what the 6 pin connector used for the rear lights wiring harness is and whether they can be bought separately new?
Re: Rear wiring harness connector
« Reply #1 on: December 01, 2016, 09:36:26 PM »
They kinda look like a Molex connector.
« Reply #2 on: December 01, 2016, 10:34:39 PM »
Are you talking about this
Max BMW has them
It only looks like you can get the blue in female and male so you will need to replace the pair
« Last Edit: December 01, 2016, 10:37:24 PM by Mrclubike »
« Reply #3 on: December 01, 2016, 11:34:26 PM »
Actually, all are available at your BMW dealer !
black (above) 61 13 1 243 297  4.07€
white              61 13 1 243 298  4.07€
Red                 61 13 1 243 299  0.69€
Blue                61 13 1 362 144  4.07€
The pin is 3.5 mm dia P/N 61 13 1 342 144 (male) and cost 1.07€ apiece... The female pin seem to be P/N 61 13 1 359  289 at 2.96€ each
There are/was also a gray one 61 13 1 243 300 (0.69€) and a beige one 61 13 1 243 675 both unavailable if I'm not mistaken.
P.S. : these are the male connectors. The female (the one from the harness that clips on the chassis of the bike) are NLA as far as I know.
« Last Edit: December 01, 2016, 11:41:25 PM by georgesgiralt »
Offline black pearl
« Reply #4 on: December 05, 2016, 09:18:51 PM »
Thanks Guys
Will follow up with the local dealers
