Author Topic: AirBox Parts - '82 R65LS - what are these?  (Read 2348 times)
Offline marcmiller001
  • "Luck is where opportunity meets preparation."
« on: November 10, 2016, 12:05:41 PM »
I went through and replaced a couple ripped/cut vaccuum lines inside the airbox but noticed that my intake is different than both the catalogs I have and the BMW dealer fiche has. Any idea on the purpose of these little jobbers in my intake suction boots?
Marc Miller
Pro Race Driver
Dodge Viper GT3-R / Porsche Cayman GT4 / Porsche 911 RSR
'82 BMW R65LS
Re: AirBox Parts - '82 R65LS - what are these?
« Reply #1 on: November 10, 2016, 01:51:18 PM »
Even though I don't have that type of airbox they are surely the discharge tubes from the engine breather.
« Reply #2 on: November 10, 2016, 02:24:32 PM »
That was a change for the crankcase vevntilation system, starting with the '82 model year bikes .
The earlier bikes, just had the rubber tube snap into the air horn .
« Reply #3 on: November 10, 2016, 02:50:00 PM »
Thanks guys - my BMW dealer can't seem to find this on their fiche... maybe I will have them look at an '83 or '84 model R65LS?
Marc Miller
Pro Race Driver
'82 BMW R65LS
« Reply #4 on: November 10, 2016, 02:50:41 PM »
...OR... do I even need this type of ventilation system? Is it more or less efficient?
Marc Miller
Pro Race Driver
'82 BMW R65LS
« Reply #5 on: November 10, 2016, 03:08:05 PM »
I not sure if it helps or not, my '82LS still drips oil from the carb on occasion .
Here's a link to the IPC for the crankcase ventilation system .
Item # 17 .
http://www.realoem.com/bmw/enUS/showparts?id=0364-USA-09-1980-248-BMW-R65&diagId=11_1713
« Last Edit: November 10, 2016, 03:09:18 PM by Bob_Roller »
« Reply #6 on: November 10, 2016, 06:29:50 PM »
Bob - mine seems to drip oil on the left side carb only... is this "normal" or a problem?
this fiche was very helpful! thanks!
Item # 17 .
Marc Miller
Pro Race Driver
'82 BMW R65LS
« Reply #7 on: November 10, 2016, 08:34:00 PM »
That's pretty much normal, Marc.
Offline mrbuck
  • i luv msbuck
« Reply #8 on: November 10, 2016, 09:49:58 PM »
Could be to prevent soft rubber tubes from being sucked flat by air passage...same as my '81 R100.
1981 R100
1998 Laverda 668
Lifan 150 cc Dirt bike
1976 Datsun 280z
1976 Datsun 620 pickup
« Reply #9 on: November 10, 2016, 09:55:15 PM »
You need to keep the engine ventilation system
But you want to delete and plug the Air injection system unless you are wanting your bike to be a "collector show bike"
The air injection is the pipes and valves that inject air into the exhaust ports
That is all the stuff  in the picture below
Some vendors sell plug kits to do this
« Last Edit: November 10, 2016, 09:57:36 PM by Mrclubike »
« Reply #10 on: November 11, 2016, 11:54:30 AM »
The reason those engine breather tubes are supported centrally with a spider is because they wanted the breather vapour to remain as vapour and pass through the carbs. If the tubes were allowed  to touch the sides there would be more chance that the vapour would condense and cause drips.  Which is of course what happens anyway but that's the reason they are supported in the inlet duct.
« Reply #11 on: November 11, 2016, 12:54:17 PM »
Mike-
Essentially - I'd be eliminating everything in the illustration you posted - except I can keep the hoses running to each carb and just plug the inlet with a vacuum cap - correct? That was my plan anyway.
Marc Miller
Pro Race Driver
'82 BMW R65LS
« Reply #12 on: November 11, 2016, 09:56:00 PM »
The vacuum port nipple  on each carb is threaded to except a screw that plugs it
or like you said you could just get a hose to span between the 2 nipples
Here is a Link to Snowbums article about it
http://bmwmotorcycletech.info/pulseair.htm
« Last Edit: November 11, 2016, 10:02:42 PM by Mrclubike »
« Reply #13 on: November 12, 2016, 04:33:46 AM »
The vacuum screws are a non preferred size of M3.5 x 0.6 so you may not easily be able to find them other than as BMW spares.  A model shop may have them or for anyone in the UK there are dozens of them in every house as M3.5 is the standard electrical thread size for switches and socket outlets.
« Last Edit: November 12, 2016, 04:37:58 AM by bhodgson »
« Reply #14 on: November 12, 2016, 10:00:46 AM »
I went with the solution of keeping the vacuum hoses to each carb and plugging the center vent "T" with a cap.
Marc Miller
Pro Race Driver
'82 BMW R65LS
