Author Topic: Forum search question  (Read 1102 times)
Offline raphski
« on: July 17, 2016, 09:06:16 PM »
Hi,
At the moment I have a fork rebuild question as I noticed mine leaking some fluid on one side. When I search the forum I come up with very little pertinent info which I find hard to believe? Is there a more refined search or am I doing something wrong? I'm sure this has been covered. What I'm looking for is a overview of the rebuild process, expense, time, and difficulty of doing the job myself.
Thanks!
Raphael
Offline tunnelrider
Re: Forum search question
« Reply #1 on: July 18, 2016, 01:36:19 AM »
I was mystified by my total lack of results searching this fantastic asylum as well Raphael, but have had more success since by changing 'This post was made in the last' field from 'week' to 'all posts' in the drop down box.  It takes a bit longer to come up with the results but should contain something you can look at.
« Reply #2 on: July 18, 2016, 05:15:26 AM »
When I search for Fork rebuild  (which means find posts with both words but not necessarily the exact phrase) I get 90 results.
Offline raphski
« Reply #3 on: July 18, 2016, 08:11:44 AM »
Thanks for the advice I will find the time frame and switch to all posts, that must be my issue.
Have a great day!
Raphael
« Reply #4 on: July 18, 2016, 08:40:02 AM »
Searching "All boards" and "All posts" takes along time so it can be quicker to restrict the search to the one board where you expect to find something  - in this case BMW Technical Q&A...
