Author Topic: Crash bar  (Read 1133 times)
Offline BooG
Crash bar
« on: June 18, 2016, 03:18:23 PM »
I want to straighten a crash bar on the R65. It is chromed, and only has a slight bend out of true. Can I heat to up with my blow torch and bend it back? Will it ruin the chrome?
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Crash bar
« Reply #1 on: June 18, 2016, 06:13:52 PM »
At the very least you will "blue' the chrome, but in all liklihood you will ruin it.
Flat black is the correct colour for crash bars anyway :-)
Re: Crash bar
« Reply #2 on: June 19, 2016, 03:12:18 AM »
I've done it with handle bars.
I tried to bend them cold and the steel just sprang back. Steel starts to weaken a long way before red heat and I took advantage of this to bend handle bars at bluing temperatures of  300-400 Deg C.  It worked and you could feel the metal bend because the spring had gone out of it. Most of the bluing polished out but I wouldn't say the finish was perfect. It didn't matter in my case as that part of the handle bar wasn't visible.
Might be worth a try using a minimum of heat to see if they will move.
