Author Topic: Charging issues - Enduralast 450w ordered  (Read 3265 times)
Re: Charging issues - Enduralast 450w ordered
« Reply #15 on: June 12, 2016, 02:15:40 AM »
Cracks int he diode board - that'll do it all right.
« Reply #16 on: June 12, 2016, 09:01:30 AM »
Yep. Pretty sure that'll correct what ails ya. Do you still plan on swapping in the EnDuraLast system?
jonathanrowley
« Reply #17 on: June 12, 2016, 11:34:45 AM »
Yep - I think again on a Bike built in 1981, time to invest in it's future and upgrade it in the process. I only bumble around at low revs, so like the idea of low RPM charging.
The Stator was pretty rusty too and so I reason that $200 on a 1981 spec system wasn't worth it. Should get it and install later this week.
jonathanrowley
« Reply #18 on: June 14, 2016, 12:24:53 PM »
So, done - took about 3 hours over two evenings as I needed to drill the mounting for the Regulator. First though I had to borrow a Drill !
Anyhow, I can report that the Enduralast kit is well documented, well put together and of a high quality. Instructions are also excellent and everything needed is in the box, including even a Rotor drift, which surprised me.
Lots of crimped connections - which I'm not 100% happy with, may have to heat solder to get peace of mind. But I got the new 450w Alternator, Regulator on and wired and the bike is charging again.
Seems like it's very powerful and is well engineered - all the old stuff has to be stripped off and dumped.
Even at low revs it pumps out 14.3 volts so looks good.
« Last Edit: June 14, 2016, 12:29:35 PM by jonathanrowley »
« Reply #19 on: June 14, 2016, 12:29:25 PM »
Hold on to that old stuff if you can. Save for the failed diode board, you may be able to help a brother Airhead with a gently used part.
There's a topic floating around the forum right now about some of us junking old parts, then discovering we, or someone else, needs 'em.
jonathanrowley
« Reply #20 on: June 14, 2016, 12:30:59 PM »
OK - only trouble is, it's in a shopping bag in the Middle East so a million miles away from any Airhead owners I think...
