Author Topic: Con rod re-install  (Read 763 times)
Offline tunnelrider
Con rod re-install
« on: March 23, 2016, 11:10:45 PM »
Hi all,
Before I remove my con rods, will I be able to get them back on with the engine still in the bike?  Seems there's just enough room to reach over and hold the cap in place but looks like it could be fiddly.  And yes I'll have new bolts.
Cheers.
Re: Con rod re-install
« Reply #1 on: March 24, 2016, 12:49:50 AM »
Hi all,
There sure is enough room. It does however help if the significant female in your life is prepared to use her probably much smaller hands to hold the bottom part against the crank whilst you offer up the upper part of the conrod and insert the bolts.  Use lots and lots of oil but ensure that the threads of the bolts and the holes they go into are dry.
Offline tunnelrider
« Reply #2 on: March 24, 2016, 08:17:54 PM »
Chur chur Tony, appreciated.
