Author Topic: 1980 Gas Tank  (Read 2421 times)
JBwell
1980 Gas Tank
« on: October 15, 2015, 09:24:55 AM »
My gas tank is not too bad inside, very little rust, BUT there are several holes that have rusted thru down around the petcock area.  Most are very small, but one is maybe 1/8'' wide and maybe 3/8 long.  Can that be cut out and welded?  Some say to use a tank sealer, some say maybe a radiator shop could fix.  I would like opinions from those on this site.  If needed, does anyone have a decent tank that would fit?  Thanks all - JON
Re: 1980 Gas Tank
« Reply #1 on: October 15, 2015, 10:43:09 AM »
That ol' demon water, collecting within the fuel tank, has brought grief to many. Condensation due to temperature swings, long-term storage with partial fuel, a neighborhood gas pump without a good in-line filter and more.
Even worse for the R65 with a single petcock, the right-hand side of the tank never drains fuel or water, unless the owner does an annual dump n' rinse. The welded tank seams are prime rust country.
A tank liner treatment may work, depending on the extent of the rust. Most good liner kits include a rust removal/neutralizer chemistry. Works fairly well with pin holes but anything larger will likely need to be brazed/welded. A wise welder would want the tank completely flushed and free of gasoline fumes. I saw a 'tube' video where a guy ran a gas welder flame over the open fuel cap and Poof! Nice sized flame erupted. Then he went on to weld up the tank.
A decent used tank, inspected for no rust, might end up being more economical. A repaired tank or its replacement would both need fresh paint so that may not factor into a decision.
   I just bought a pair of gently used BMW handlebars from Larry Stonestreet; owner, operator and janitor of Cali-based Stoner's BMW Stash. Hit him up for a used R65 tank. He's an Airhead good guy. No web site but email works fine. <ca.stoner@yahoo.com>
JBwell
Re: 1980 Gas Tank
« Reply #2 on: October 15, 2015, 06:16:58 PM »
Can anyone tell me what years of tanks will interchange?  I know the 1980 r65 has a lot of parts that will and a lot that wont!  Thanks AGAIN!!
Re: 1980 Gas Tank
« Reply #3 on: October 15, 2015, 10:40:33 PM »
You should be able to use any R65 fuel tank. The 1978-1980 models and the 1981-1984 differences were mainly in the engine, carbs, ignition, brakes, rear sub frame including the drive shaft and swing arm, plus the seat cover design. A few other differences but none that should keep you from utilizing an "any year" R65 fuel tank.
Re: 1980 Gas Tank
« Reply #4 on: October 16, 2015, 07:17:46 AM »
Not so Monte.
The 1979/80 tans will not fit on the 1981/85 bikes due to changes in the way the electricals are mounted, the later tank has a significantly different shape on the RHS bottom portion.
I can however confirm that the 1981/85 tank will fit the 1979/80 frame, just not the other way around.
Re: 1980 Gas Tank
« Reply #5 on: October 16, 2015, 08:43:43 AM »
... The 1979/80 tans will not fit on the 1981/85 bikes due to changes in the way the electricals are mounted, the later tank has a significantly different shape on the RHS bottom portion.
I realized that under tank recess issue just as I was nodding off late last evening. With the shift to the 'electronic' ignition in '81, there is quite a bit of lumpy stuff on the right side of the main frame's tank area. Thanks for the reminder, Tony.
JBwell
Re: 1980 Gas Tank
« Reply #6 on: October 16, 2015, 08:47:11 AM »
Ok so it looks like a tank from a 79-85 r65 will fit my 80.  I have contacted those that were suggested here, no luck, and they have referred me to some others, no luck again.  So please be on the lookout if any of you hear of a decent tank for sale.  I looked on ebay and there are some, but as we all know you just never know...  I have time, I mean we will have our first frost tomorrow morning so I really don't need a tank till we have our LAST frost next spring.  Once again thanks everyone for all the help and info.  JON
Offline Mike V
  • 78 R100/7 , 81 R65
Re: 1980 Gas Tank
« Reply #7 on: October 16, 2015, 09:11:23 AM »
JB,
Have you tried Larry Stonestreet  aka; "stoner" at Stoner's Beemer Stash?
email:
ca.stoner@yahoo.com
http://bmwcaferacer.tumblr.com/post/21500436354/stoners-beemer-stash-bmw-bikes-parts-larry
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
JBwell
Re: 1980 Gas Tank
« Reply #8 on: October 17, 2015, 03:35:37 PM »
Yes I did get hold of Stoner but he had nothing for me at this time.  I did locate a NOS really nice
LS tank out west, but since my bike hasn't run for years its a bit early for me to drop that much cash on a tank.  So... I know this is temporary, but, I used some Permatex gas tank repair,  Its a roll of 2 part epoxy that you knead together, then cram it in the holes.  After the first try I still had a little leak so I sanded it off and jammed another gob or two in there.  Sounds real professional huh!  But it is soaking now with gas in it and no leaks yet.  At some point I am sure a new tank will come my way.  JB
