Author Topic: tire trouble  (Read 1435 times)
stevie
tire trouble
« on: September 21, 2007, 11:21:43 AM »
Hello lads and lasses
Its been a while since I posted but finally getting round to doing some work on my bike after 2yrs lying idle in the garage. Anyways started putting on a new pair of tyres only for me to firstly  somehow puncture the tube in the front (aaaaahhhhh!) wheel. Managed the rear ok but having trouble seating the bead correctly on the rim. Any advice gratefully received
cheers Steve.
Re: tire trouble
« Reply #1 on: September 21, 2007, 11:38:28 AM »
How much pressure are you using to try to seat it?  Warm tire, lubed?  The last one I did I had to let it sit for several minutes before both sides popped into place.
stevie
Re: tire trouble
« Reply #2 on: September 21, 2007, 12:50:13 PM »
Hi ed
Currently using a foot pump, but gonna take it round to my pa,s to use his compressor, hopefully this will do the trick
thrang
Re: tire trouble
« Reply #3 on: September 22, 2007, 10:10:08 AM »
A good bodge on a coolish day when the tyre is stiff is to steal a hairdryer and run it round the tyre before you pop it on to the wheel.
Re: tire trouble
« Reply #4 on: September 22, 2007, 11:41:20 AM »
Never going to happen with a "foot" pump.  You need to lube/soap the hell out of it, warm as suggested, and I have had to put close to 100 psi in some to get it to seat!  I don't know what the safety limit is and I am not telling you to automatically put in 100 psi.
stevie
Re: tire trouble
« Reply #5 on: September 22, 2007, 12:47:06 PM »
Cheeers fellas got it sorted with the help of around 80psi and soapy water as suggested
Cheers Steve.
tagordon
Re: tire trouble
« Reply #6 on: September 23, 2007, 07:42:23 PM »
Great! Now go break in those tires.
dewjantim
Re: tire trouble
« Reply #7 on: September 24, 2007, 08:02:30 AM »
Be sure to ride carefully the first 10 miles or so, those new tires are usually pretty slick at first.....Dew.
