Author Topic: Timing chain removal/installation  (Read 7021 times)
Re: Timing chain removal/installation
« Reply #15 on: March 29, 2015, 02:37:18 PM »
Besides photos, there is a healthy bit of text explanations that are quite important, so...
Go to the forum home page and click the "members" tab. Highlighter in red is our Admin, Justin. Send him a PM with your request. Also try Bob Roller for assistance if no joy from Justin.
That's the best I can do for ya. The forum does need some way to help new members get into the photo gallery.
« Reply #16 on: March 30, 2015, 07:59:33 PM »
I'm sorry - I also do not have the keys to the photogallery - even though it is linked to the forum it has its own admin account & settings, and neither Bob nor I have them at this time.
We'll see if we can rouse Justin, and maybe come up with a backup plan for the future.
« Reply #17 on: March 31, 2015, 07:50:37 PM »
Rec'd this evening an email from the R65 forum administrator, Justin Bowser"
I've set 3 people up today for access.  All they have to do is PM me.  One mentioned that a thread said to contact Rob.  I'll make a new thread with instructions.
Monte Miller wrote:
Some members requesting access to the Photo Gallery. Neither Bob nor Mike can assist with a "kitchen pass". The group needs either your assistance. Perhaps allow your sub-administrators to help active forum members? Appreciate any help you may be able to provide.
Offline jamestnewsonr65
« Reply #18 on: April 07, 2015, 09:45:34 AM »
I removed my timing chain cover today and changed the chain, tensioner etc, but I fear it may all not be good.
I had the bike in gear so that the wheel would not move but once the chain was removed the wheel was turned slightly so that I now fear the timing sprockets are out of alignment. Is this a major disaster???
1981 R65 (box of bits).
« Reply #19 on: April 07, 2015, 09:54:37 AM »
If the timing marks are off, yes it will be a major issue .
Getting the marks aligned is not difficult, but you need to lay on the floor in front of the engine and get a good view of the two marks .
« Reply #20 on: April 07, 2015, 10:01:44 AM »
I can see the mark on the camshaft sprocket as it is on the front inline with the woodruff key. Where is the one on the timing sproket?
« Reply #21 on: April 07, 2015, 10:13:51 AM »
The timing mark on the crankshaft sprocket, isn't very visible due to the bearing on the end, but if you look at it like I said in my previous post, it's easily viewed .
« Last Edit: April 07, 2015, 10:15:01 AM by Bob_Roller »
« Reply #22 on: April 07, 2015, 10:43:09 AM »
There is a very faint mark in the pic below, but apart from this I can not see any other marks on the sprocket or shaft etc.
It appears as a small dink in the ring on the outside shown in the yellow box on the image
« Reply #23 on: April 07, 2015, 11:27:57 AM »
Any tips on where I should be seeing the timing mark on the top sprocket are gratefully received.
« Reply #24 on: April 07, 2015, 12:33:22 PM »
Did you have the engine at TDC and the cam gear's "dot" at 12 o'clock before removing the chain? I'm guessing you left the spark plugs installed and, if not at TDC, perhaps compression caused the crank to turn a bit. If the cam gear was in the 12 o'clock position when you removed the chain, it's doubtful the crank gear would move much at all. But you must confirm this.
The mark you have high lighted is not a timing mark. Appears to be a slight nick from a PO's maintenance chore. The mark you are looking for is a tiny, single etched line approx 0.25-0.375 inch long and well hidden by the bearing. I tried all sorts of mirrors, lights and creative language but never could spot it.
Another option is to get the right side piston at TDC. It should be very close as is. Watch the rocker arms and look into the spark plug opening for confirmation. Check the flywheel for the "OT" On Top marks. When in position, the crankshaft gear should be in alignment
Install the chain and by hand s-l-o-w-l-y rotate the engine in the running rotation. Slowly! If you are a tooth off, there will be valve-to-piston contact. Go slowly and do not force the crank to turn any further. If the engine rotates freely, you should be ok.
Did you ever get into the Photo Gallery? Could have saved you a lotta time and worry.
« Reply #25 on: April 07, 2015, 03:14:41 PM »
Thanks for the reply. It is a bit daunting for a novice like me, but you would have thought after 10 years of classic car ownership I would be used to getting my hands dirty!!
I do have access to the image gallery now and it is a massive oversight on my part not to set the engine to TDC before starting really.
Everything was fine in the removal of the timing cover and it came off with ease. The engine is still in the bike which is fine and the cover came off despite the engine still in the frame.
The problems came when I started to replace the timing chain. The lower sprocket timing mark was at about 7 o'clock in position and the removable chain link was in a very difficult position to get to.
So I put the bike into 5th and rotated the back wheel so that the link was in a better position to remove. Once the chain was removed the rear wheel was turned again as I wanted to feed some of the chain through. It was at this point I realised my newbie mistake and have no way of knowing where the alignment now sits.
The engine was NOT at TDC when I started.
The pictures shows how it is at the moment. I put the tensioner and chain in just so that I know where all the bits are and I know the chain link is not fixed in this picture also.
I tried to spot the timing line on the top sprocket but could not see anything. Do you know where it should be? On the horizontal section or vertical etc?
One I thing I did notice is that the tapered end has a definite mark on it (visible in the pic) like a timing mark as it seems more deliberate. For now I aligned it to this as I did not know what the timing mark looked like.
I understand that I will have to remove all of the chain etc to get the correct alignment but am just a little unsure of how to tell where the bloody mark is.
Thanks for the help so far. It really is an invaluable resource.
« Reply #26 on: April 07, 2015, 05:07:08 PM »
If you lay down on the floor to the side of the engine and look up, you can see the mark on the tooth of the crankshaft sprocket easily, but if you try to view it from any other angle, the bearing gets in the way .
« Reply #27 on: April 07, 2015, 05:11:18 PM »
If it is on the tooth I can understand why it is difficult to find. I will have another crack at finding it again tomorrow and let you know how I get on.
I might get it close by following monte's suggestion with the right hand cylinder then at least I will know that the timing mark should be close to where it needs to be which might make finding it easier.
« Reply #28 on: April 07, 2015, 09:59:37 PM »
My recent experience with my wife's bike (R65 with 1987 R80 engine in it) was that I could not find a timing mark on the crank gear. I set the engine to the valve timing mark and turned the cam so that the mark on it was at 12 o'clock. I turned over the engine a few times to satisfy myself that all was well and then tossed it back together. I figure that the maximum error would be a tooth either way and over the years BMW has fiddled with cam timing to a greater extent than that.
In retrospect I think that the crank gear mark was simply worn off as the new gear had one.
« Reply #29 on: April 08, 2015, 11:23:21 AM »
Ok so today I have some progress which I think is good.
I think I may have found the elusive timing mark! With the valve timing set to tdc by rotating the wheel and making sure OT mark was aligned there was a vertical mark on the sprocket teeth which was very faint but I think it was there.
I marked the end of the tapered shaft so that it was easier to know where the mark was and checked the faint timing mark was aligned correctly
At the moment when the marks are aligned and OT is visible, the left hand cylinder (if I was sitting on the bike) is free and at tdc. I confirmed this by spinning the valve rods.
The 2 pictures below show the marks in relation to the right and left at TDC respectively if viewed from sitting on the bike.
Hopefully this is all ok now and the engine turned over easily enough without the spark plugs in. I guess if there were any valve to cylinder moments then it would be noticeable in the rotation force needed to turn the engine.
I have a couple of questions though....
- How tight does the guide rail on the left of the timing chain need to be?
- The nuts in the centre of the valve covers have cross threaded, is it possible to buy the stud and nut?
Thanks for all the help and hopefully it is all ok. Any comments welcome.
« Last Edit: April 08, 2015, 11:37:05 AM by jamestnewsonr65 »
