Author Topic: 84 R65LS Steel braided brake lines, standard bars  (Read 6683 times)
Zamp
« on: April 16, 2015, 04:55:17 PM »
Any suggestions on where I can get some steel braided brake lines for my 84 65ls. I recently got the bike, and see the bars are standard high, not original.  I called Bob's BMW, and they suggested standard R65 kit, but isn't that for single disk front?
Re: 84 R65LS Steel braided brake lines, standard bars
« Reply #1 on: April 16, 2015, 05:57:08 PM »
You're probably going to have problems getting a set of lines for a dual disc with high bars .
You most likely will get a set for an LS with short bars .
Here's a suggestion for a source .
 http://spieglerusa.com/
Call them up and tell them what you have .
Worst case scenario, is to send them the lines and they will fabricate new ones for you exactly the same as the ones that came off, with the exception, that all the hose ends will most likely have  ' banjo ' fittings and hollow bolts, not threaded fittings .
Price is around $140US, plus shipping .
« Last Edit: April 16, 2015, 06:00:55 PM by Bob_Roller »
« Reply #2 on: April 16, 2015, 09:29:53 PM »
You can also try here... http://www.pashnit.com/product/index.html and they are located in your state. I bought a set of Galfer stainless lines from them for my R65LS with standard high bars. While I no longer have the LS fairing I had no fitment problems at all. If you check the fitment page there is a specific set for R65LS dual brakes. I have had them installed for a couple of years now and it was the best investment in braking I have made.
You can get them in standard stainless or all sorts of colors for the covering over the stainless hose. They also can add colored banjo fittings if you are trying for a specific color scheme.  All the extras add extra $$ to the price.
« Reply #3 on: April 17, 2015, 12:53:13 AM »
If, and I stress the word "IF" you have a standard braking system for your year/model then you have:-
A rubber hose from the master cylinder to a point adjacent to the left hand handbar mount where the rubber hoses attaches to a roughly "U" shaped steel pipe. The steel pipe is connected to a bronze "splitter" which is bolted to the headlight/instrument support bracket. The "splitter" has a brake switch and two rubber hoses attached to it - the rubber hoses head downwards until they meet a steel pipe fitting which in turn connects to the caliper.
If you have this system, then all you need change to allow for higher bars is the hose from the master cylinder to the "U" pipe.
If you do not have a system as above then a PO has messed with it and you are on your own.
« Reply #4 on: April 17, 2015, 07:29:03 AM »
The standard LS setup, is one rubber line from the master cylinder, to the brake line splitter, behind the head light bucket .
Both ends of the line , if it is stock, has banjo fittings on each end .
If a previous owner replaced the handlebars, hard to say what you may have there .
Suggestion, is to remove what needs to be, get a good look at your particular setup is .
« Last Edit: April 17, 2015, 08:19:11 AM by Bob_Roller »
Zamp
« Reply #5 on: April 17, 2015, 09:23:27 AM »
thanks everyone for your suggestions on steel braided lines.  I am considering also changing the rotors, the ones that came on the bike are grooved quite a bit. That and new pads hopefully will improve braking substantially.  I ride LA freeways to get to fun mountain road.  Can use all the braking I can get, and yesterday a good size deer crossed my path on Hwy 2. Thanks again
« Reply #6 on: April 17, 2015, 09:58:12 AM »
Don't expect a dramatic increase in braking power, with new lines, rotors and pads .
This is the only area of the R65, that I would like to see get better, the stock set up is not the most powerful brake system .
mdecnsp
« Reply #7 on: April 17, 2015, 10:09:22 AM »
I had my coated steel brake lines for my 82 LS made to fit at an automotive performance plumbing supply shop. Cost me about $115.
Don't know where you are in LA but I took my old lines to Earls Performance Plumbing shop in Lawndale. It's right off the 405 at Hawthorne Blvd. He did the job in about 45 min. He recommended not to get the clear coated, that they yellow over time and look bad. Got the brown coated... look great.
thrang
« Reply #8 on: April 17, 2015, 01:57:27 PM »
I got a set for my LS, on standard LS bars, from Motobins, they cost about £80, and were a doodle to fit. The braided lines do improve performance, but not massively, and like Bob said its the one area where BMW got it wrong.
« Reply #9 on: April 17, 2015, 02:08:00 PM »
After all the years and miles I spent on my 1953 Triumph, I believe the R65 has bloody marvelous brakes.  :D
« Reply #10 on: April 17, 2015, 04:31:18 PM »
I fitted high bars on my R65 and fitted braided lines, the pipe from the master cylinder to the brass splitter I had fabricated by a local hydraulic hose supplier. its a standard 1/4inch BSP male end with a 1/4inch "banjo" bolt fitting to the master cylinder.
« Reply #11 on: April 17, 2015, 06:02:25 PM »
As a newest owner of the R65LS, it may be only guessing as to the maintenance performed by the PO.
Before spending too much dinero, suggest removing the disc brake pads and checking their condition. They may be worn thin, oil or hyd fluid soaked or the wrong compound. EBC produces an organic pad for the R65 that is quite good. Avoid any metallic impregnated pads as they do rapidly wear the BMW's stainless brake disc/s.
Completely flush the old brake juice from the system. Brake fluid is hygroscopic; it absorbs water which does a poor job when mixed with brake fluid. Water-infused brake fluid can also lead to corrosion and/or rust within the system.
Also, use a green ScotchBrite pad and a can of carb cleaner to do a scrubbing number on the discs. Both sides and the inside of every drilled hole should receive attention.
Completely drain the brake system and flush with new. Bleed all air from the lines. Speed Bleeders can make this process a one-man job. A hefty rubber band, used to tie back the brake lever, will aid in forcing the last tiny bubbles from the system when left in situ overnight.
New pads will need a couple hundred miles to conform to the existing wear patterns in the discs. After they bed in, braking performance should be much improved.
Stainless brakes hoses look terrific. However, they are not a cure all for a system needing basic maintenance.
Offline SoloLobo
« Reply #12 on: April 17, 2015, 06:24:50 PM »
I'd say to contact cyclebrakes.com who do custom (galfer)lines at good prices, I've done several lines through them.
Also, I always use Galfer Green organic pads.  Great stopping power and minimal wear on the discs.
You can also bypass the spliter and run two longer hoses up to the M/S and use a longer bolt.
thrang
« Reply #13 on: April 18, 2015, 12:05:42 PM »
I really want some speed bleeders! Have spent a lovely afternoon in the sun fitting a set of braided lines to my LS. I had all the usual bleeding problems (mucho swearing)  but sorted now :) even so am leaving over night with a cable tie round the leaver to flush out any last air bubbles.
« Reply #14 on: April 18, 2015, 12:43:38 PM »
Everyone has their own preference for bleeding brakes, I've used a vacuum bleeder type for the last 20 years .
One member here had issues with speed bleeder screws, the threads have a Loctite type material on them and the bleeder screw bound up and came close to stripping all the threads in the caliper .
