Author Topic: mileage  (Read 4241 times)
Re: mileage
« Reply #15 on: August 21, 2014, 11:56:16 AM »
That's an interesting one and in percentage terms a very big difference. The gear box absorbs power at the best of times. Failing bearings and resultant misalignment would absorb even more than usual and use more fuel.
Offline Andrewsteward
Re: mileage
« Reply #16 on: August 22, 2014, 01:21:42 AM »
So here's a grim thought: not that long ago I was getting around US 33 mpg.. I ended up getting the transmission rebuilt and now I'm up to 41+ mpg.
Either the transmission rebuild or the new rear shock made the difference.
mmm lests note hope for a tranny re-build.
just pulling carbs apart now
Re: mileage
« Reply #17 on: August 22, 2014, 02:44:19 AM »
Ok first report-nothing much to report though.
Needles position 3 though left side circlip a little dis-logged but only about 0.5mm difference.
Main jet 145. Couldn't tell what the needles were. No markings.
Still running well, havnt run a full tank yet so cant tell about consumption.
plug colours are perfect.
Compression is at 110/side so yes getting tired, so maybe adding to the consumption problem.
Just wondering if the clutch maybe slipping? Its not apparent but just a thought.
How many revs should it be at 80k or 50mph?
I do have a noise when the clutch is engaged. I might try and post it
Re: mileage
« Reply #18 on: August 22, 2014, 11:43:13 AM »
....Couldn't tell what the needles were. No markings.
The needle should be a 46-241 which is used in the majority of Bing carbs on Airheads. I suppose it's possible someone substituted the wrong needle but it's not something you hear about often if ever. I have some reasonably accurate dimensions for a 46-241 needle if you want to measure yours. They are easy to measure as our needles are a simple straight tapered cone. That's not true of all Bing needles in other applications though.
Needle diameter 2.45mm
length of tapered section  23mm
Minimum diameter of taper 1.2mm
Re: mileage
« Reply #19 on: September 02, 2014, 04:24:47 AM »
Thanks Barry, I will check on the weekend.
Slow
Re: mileage
« Reply #20 on: October 27, 2014, 01:22:12 PM »
I just seem to be lucky then, my motocycle gives me 20km/l and that is combined cycle, hi way and town driving.
Re: mileage
« Reply #21 on: October 27, 2014, 03:19:58 PM »
OK multiply 20km/l by 2.824809363 and we get 56.5 MPG (IMP) or 47 MPG (US).
Not bad at all.
