Author Topic: R65-R65LS Carb Differences  (Read 1103 times)
« on: September 10, 2007, 08:50:21 PM »
I was looking through the Bing manual I got about 4 months ago, looking for an answer for a posting on Boxerworks, about high altitude operation, and I was looking at the section about what jets, and needles are used on the R65, and found that the R65LS is jetted differently than a standard R65. The slides, main jet, needle jet, jet needle, idle jet, and float bowl are all different on the LS. I thought they were all the same ! From the looks of the correction chart for temperature and altitude, I should be using different main jets for hot weather operation.
« Last Edit: September 11, 2007, 06:33:52 PM by Bob_Roller »
tagordon
Re: R65-R65LS Carb Differences
« Reply #1 on: September 11, 2007, 01:14:37 AM »
Are the carbs the same part#(s)
Are the specs for the same carbs on the same engine just diff' body & frame.
I wonder as to the weight to HP ratio also for a R65 vs R65LS.
I would compare the constants against the variables.
That is if I weren't so busy with my recently aquired bike. Got parts laying all over the place. And gotta get it back together to get it inspected for registering it for new title.
« Reply #2 on: September 11, 2007, 10:24:14 AM »
The carbs are a different part number : 64/32/335 and 336. There are 2 different sets of flat-top carb part numbers, 5 different sets for a standard 'dome top' carb, one set for the LS, and 5 different sets for the R65RT. So I guess if you are buying a set or just one carb for your R65, you need to know what you're getting, or it may lead to problems running correctly. According to  the altitude / temperature correction chart, I should be using jets for riding at 5000 ft elevation for the hot season here in Phoenix (density altitude).
« Last Edit: September 11, 2007, 12:07:46 PM by Bob_Roller »
