Author Topic: First drive  (Read 2627 times)
Offline jamestnewsonr65
Re: First drive
« Reply #15 on: September 15, 2014, 09:37:25 AM »
I adjusted the freeplay on the lever to achieve more distance on the arm, but this was just to see if it worked. I need to adjust it properly again before getting it MOT'd. Will go by the book and set the correct distance and freeplay again. At the moment it has too much freeplay and the distance is about 210mm from the case.
1981 R65 (box of bits).
