Author Topic: Wire colours  (Read 1965 times)
Offline BooG
Wire colours
« on: July 19, 2014, 03:37:41 AM »
Hi.
I need to do some work on the loom, but I am having difficulty tracking down the correct wire color combinations. Anyone know where I can source appropriate cable in the UK? I am after the grey and black wire that runs between parking lamp etc.
Thanks!
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Wire colours
« Reply #1 on: July 19, 2014, 04:40:38 AM »
Vehicle wiring products do slate/black which sounds like it might be the right colour.
http://www.vehicle-wiring-products.eu/VWP-onlinestore/cable/thinwall.php
« Last Edit: July 19, 2014, 04:42:26 AM by bhodgson »
Offline BooG
Re: Wire colours
« Reply #2 on: July 20, 2014, 02:05:43 PM »
Perfect!!
Many thanks!
BMW R65 1980.
BMW K75S 1987
Offline BooG
Re: Wire colours
« Reply #3 on: July 21, 2014, 11:13:12 AM »
Just looking at the schematic in my Haynes manual....punctuating the slate/black cable running from the parking lamp to the connector block, is the number .75.   Does this refer to mm squared, or if not, ??? :-?
BMW R65 1980.
BMW K75S 1987
Re: Wire colours
« Reply #4 on: July 21, 2014, 11:56:50 AM »
Offline BooG
Re: Wire colours
« Reply #5 on: July 21, 2014, 12:28:21 PM »
Nice one!
Now, it appears I can only get cable at either .5mm (11amps), or 1mm (16.5amps). What would be preferable? I'm assuming 1mm at the mo...
BMW R65 1980.
BMW K75S 1987
Re: Wire colours
« Reply #6 on: July 21, 2014, 12:55:12 PM »
The wiring harness pretty much standardizes on 0.75mm2 regardless of need but in the particular case of the parking lamp 0.5mm2 would be more than big enough.  There is no chance that the parking lamp could draw 11 amps.
To get deeper into electrical circuit design the only other consideration is that in the case of a short circuit the loop resistance is low enough to blow the fuse. 0.5mm2 cable has slightly higher resistance but the length of wire is so short that it wouldn't remotely be a problem.
« Last Edit: July 21, 2014, 01:02:56 PM by bhodgson »
Offline BooG
Re: Wire colours
« Reply #7 on: July 21, 2014, 01:08:37 PM »
Thanks guys!
That's why I love the forum!! ;D
BMW R65 1980.
BMW K75S 1987
Offline BooG
Re: Wire colours
« Reply #8 on: July 21, 2014, 01:15:27 PM »
and of course...they only do .5mm in slate, and not slate and black!!
They do 1mm in slate and black however...?? >:(
Stay true to the colour scheme and go with 1mm slate/black, or, slate grey .5mm??!
BMW R65 1980.
BMW K75S 1987
Re: Wire colours
« Reply #9 on: July 21, 2014, 02:58:15 PM »
The bigger cable will function fine, it's going to be slightly larger in diameter that's all.
