Author Topic: good way of moving the needles in the carbs?  (Read 818 times)
Jon_P
« on: August 29, 2007, 10:19:48 AM »
what is a good way to remove the little clips that hold the needles? i want to do some adjustments on them and i was wondering if i need to get some new clips or can i reuse them a couple times till they start to break. how have you removed those clips???
Re: good way of moving the needles in the carbs?
« Reply #1 on: August 29, 2007, 10:41:45 AM »
I removed them when I rebuilt the carbs a few months ago, I took a piece of hardwood and put it on the needle and tapped on the wood, and the 'star washer' and the needles came right out. As far as reusing them, it all depends on what shape they are. I was able to reuse mine, but knowing what I know now, I would replace them instead of re-using them. I had a bit of trouble getting the needles back in when I was re-assembling the carbs, and after looking at the exploded view in the Bing Agency manual, there is an upgrade for this problem, looks like it may involve a rubber plug  that the needle goes through instead of using a 'hairspring' metal clip that engages the slots of the needle. I found that the left carb had the needle set to position 2, and the right carb to the correct position 3. It was that way from the factory.
« Last Edit: August 29, 2007, 10:47:24 AM by Bob_Roller »
