Author Topic: tires/tubes for my R65  (Read 6691 times)
Re: tires/tubes for my R65
« Reply #15 on: March 19, 2014, 04:00:44 PM »
Those handlebars are LS, right?  ::)
tc80211
« Reply #16 on: March 19, 2014, 09:37:24 PM »
Honestly no idea what this bike started life as. It certainly was rough to say the least... Tank has "patches" welded into one side where he removed 1 petcock... Vetter fairing that was def not fit correctly... Original seat though... So R65 for sure. Trying to bring it back to its stock R65 glory with some needed enhancements...
« Reply #17 on: March 20, 2014, 01:37:44 AM »
Hello !
NO, you CAN'T run tubeless tires on them.
Snowflakes rinms are NOT designed to run tubeless tires.
Some use them and had no accident still. But this is pure luck.
Tubeless rims have a different profile than the one on the snowflakes rims.
« Reply #18 on: March 20, 2014, 07:45:41 AM »
Welded patches, you say? If that tank is an OEM R65 fuel tank, it was never a two-petcock-er. R65s have a single petcock on the left side. We are unique in having close to a quart+ of fuel stored on the right side of the tank. All you need do is tilt the bike a bit and slosh enough Reserved reserve fuel to get you several miles further down the road. Could mean less or no pushing.
The lower seam area on your tank -and for the rest of us, too- is also an excellent water trap. Eventually, rust eats through the seam area and you have a nasty leak. Thinking that's the real reason for the patches on the right side of your tank.
An annual ritual of removing the tank and draining the fuel along with any accumulated water is a good preventative measure in preventing rust, leaks and wallet burn.
« Reply #19 on: March 20, 2014, 08:31:36 AM »
I'll give my usual take on snowflakes and tubeless tires. No it was not designed for tubeless use but it was designed as  safety rim to :-
"improve stability should a tire blow out. The shape of the rim itself provides some support for the deflated tire as well as holding it firmly on the rim. BMW consider this to be a more important development than tubeless tires  which they feel presents private owners with numerous pitfalls regarding safe fitting and adequate sealing"
Taken from a 79 road test and presumably the sort of press release information BMW gave out at the time our models were introduced.
« Last Edit: March 20, 2014, 08:33:19 AM by bhodgson »
tc80211
« Reply #20 on: March 20, 2014, 08:54:46 AM »
I will be "diving" into the tank this weekend to get a closer look at to what is up... Thinking the KBS sealing system to cleana nd seal its interior...
As for tires, I think Spitfire after reading Snowbums page, he makes a convincing argument and I want the best ride quality I can get....
Only a couple hundred other parts left to go!
« Reply #21 on: March 20, 2014, 11:56:29 AM »
if brake shoes are on the list, don't get them that fit the LS (the LS wheels have a bigger drum and mucho-more-expensive shoes).
You'll be happy with the spitfires, they're a great all around tire.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #22 on: March 20, 2014, 01:38:18 PM »
'84 and older, Monte.. don't forgot about those monoshockers!
I treat mine like a single petcock though.
'04 R1150 RT ~41000 miles
« Reply #23 on: March 20, 2014, 05:08:02 PM »
Either deliberately give your bike a dose of Ethanol blended fuel or every 6 month sor so give it a tank of high octane and add a bottle of methylated spirits.
This is making use of chemistry. Water does not dissolve in petrol, but alcohol does. Water dissolves (and this is the wrong term cause right at this moment I can't remember the right one) in alcohol.
Petrol/alcohol/water comprise an intermiscible solution which gets rid of any water that has accumulated in the bottom of your tank without all that tedious removal, sloshing about and use of hair dryers etc.
Mainerider
« Reply #24 on: March 20, 2014, 06:07:24 PM »
Alcohol fuel is all we can get around here. :(
Steven
« Reply #25 on: March 20, 2014, 06:10:22 PM »
Monoshockers are just too modern for me.  ::)  Oldskool don'cha know.
livingdeadhead
« Reply #26 on: March 20, 2014, 06:15:45 PM »
these! cheap as chips and great! michelin m45 s less than £100 quid fitted .
« Last Edit: March 20, 2014, 06:16:32 PM by livingdeadhead »
« Reply #27 on: March 20, 2014, 10:04:04 PM »
To perpetuate a tire thread,  I'm ordering a new set of Bridgestone Spitfire S11s, along with new Bridgestone tubes. A question asked online is whether I want a TR-4 / TR-6 Straight metal stem (8mm dia.), or PV78 Tall 90 degree metal stem. I like the idea of using the 90 degree valve stems, and wanted to ask if anyone here has tried them, yea or nay. Getting to the straight stems with the snowflake wheels can be a wee bit difficult at times, or at least more so than a 90 stem, and using some pressure gauges would be much easier too. Thoughts?
« Last Edit: March 20, 2014, 10:05:31 PM by NC_Steve »
« Reply #28 on: March 20, 2014, 10:53:14 PM »
You shouldn't have any trouble with a 90 degree stem.  You might slightly change the weight of the valve assembly... and you might also slightly change the center of gravity of the valve assembly.
As long as the wheels are balanced with the 90 degree stems--if you bother-- you won't notice a difference; and having your valves easier to access with an air chuck/pressure gauge will probably promote better and more frequent tire pressure checks and adjustments.
« Last Edit: March 20, 2014, 10:54:26 PM by Luca »
« Reply #29 on: March 21, 2014, 03:32:14 AM »
Lou uses them and I've bought a set to be fitted later this year. I reckon the low price is down to them being marketed as commuter tires. Michelin actually recommend them for fitment for my bike.
