Author Topic: Clutch bolt torque  (Read 2208 times)
Re: Clutch bolt torque
« Reply #15 on: March 11, 2014, 09:07:40 PM »
Tony: I was talking in nm, not ft/lbs. So 20nm = ~15ft/lbs.  I'm still fortunate they didn't break tho!
You surely are, hence my feeling that if you were talking ft/lbs that your torque wrench needed adjustment or discarding :-)  I was mislead because all the other posts were talking ft/lbs.  I am glad that you are not facing buying a new Torque wrench.
I also think, given the trivial amount of money involved, that replacing the bolts is a fine idea.
May I offer a tip on clutch centering - beg borrow or steel a dial gauge and center that clutch plate as near as perfect as you can. Then when you fit the transmission to a clutch you know is perfectly centered, run the mounting bolts straight up to torque in three stages. I suspect that the manuals still have nonsense in them about leaving the mounting bolts slack, starting the engine and then engaging and disengaging the clutch - in my opinion a perfect way to ensure that your clutch and gearbox input shaft act like an epicyclic gear.
Why BMW didn't accept the 10pfennigs increase in manufacturing cost and allow for and fit a spigot bearing is quite beyond me. I suspect it was a Teutonic extension of the middle finger to convention.
« Reply #16 on: March 12, 2014, 01:30:48 AM »
Can't read anymore ...  :'( :'(
« Reply #17 on: March 12, 2014, 06:05:02 AM »
I made a clutch centering tool with a 16mm socket and a bolt I turned down. I've already mated the tranny to the engine on the bench. I thought that confirmed that the clutch was centered adequately?
I've never heard of leaving the tranny bolts loose while starting the engine! I haven't gotten to that point in the Clymer manual, but I'll look for that.
« Reply #18 on: March 12, 2014, 07:34:04 PM »
I just bolt the tranny on , tightening the mounting bolts in stages, but don't leave anything slack.   With a centering arbor your clutch will be properly aligned.  Now there *were* some Kbikes and oilheads that had slightly misaligned gearbox mounting holes, but I've never heard of such a thing on any airhead.
« Reply #19 on: March 16, 2014, 06:44:40 PM »
They are 6mm bolt in the 1979 and 1980 heavy flywheel clutches.
6 ft-lbs and a little blue Locktite and no more.  This is secret information only known to us.
BMW didn't think it important to tell us this information.  20 ft-lbs means stretched bolts liable to break.  Remove and replace these now defective bolts.  Sorry.
