Author Topic: '79 R65 tank on my '83 R65 LS?  (Read 1601 times)
tc80211
« on: February 20, 2014, 03:26:23 PM »
Hey guys,
Will a '79 R65 tank fit on my '83 R65 LS?
Re: '79 R65 tank on my '83 R65 LS?
« Reply #1 on: February 20, 2014, 05:09:00 PM »
AFAIK all R45/R65 tanks 79 to 84 are the same. Seats, rear  sub frame and under seat storage do differ between early and later models.  Check the online parts fiches and I think you'll find the same part numbers for an LS and early R65 tank.
« Last Edit: February 20, 2014, 05:19:50 PM by bhodgson »
« Reply #2 on: February 20, 2014, 07:30:35 PM »
I think the tunnel is different on the "1st" gen & the "2nd" generation bikes, due to the different layout of the electrics between the two.
I could be wrong.
« Reply #3 on: February 20, 2014, 07:31:22 PM »
Barry not so I am afraid.
A 81 and later tank will fit a 79/80, but not the other way around. It is due to the differently shaped pressing on  the underside of the tank to clear the  the ignition trigger and other additional electronics on the post 81 bikes. I did once consider a "lump of timber and house brick" method of adjustment, but happily I was able to locate a better tank that fitted my 85 twin shock.
« Reply #4 on: February 21, 2014, 03:02:13 AM »
...mm  so what that amounts to is that the current spare part is a later tank because it fits both.
Shows you can't altogether trust the on line fiche part numbers as they show the "current spare" which is not necessarily the same as the original part.
tc80211
« Reply #5 on: February 23, 2014, 12:12:24 AM »
thanks guys. ill keep searching for a better matched tank for my '83
