Author Topic: steering damper  (Read 1716 times)
Offline Bill Conquest
steering damper
« on: December 19, 2013, 12:07:11 AM »
Hi Everyone, I'm looking for a steering damper for the '79 R65 & they are expensive,anyone know of a reasonable  alternative,,used maybe?
Thanks, Bill
79 r65/75 r60/76r75/76r100
Re: steering damper
« Reply #1 on: December 19, 2013, 12:30:25 AM »
You should not need one, if the front end is in good shape.
Re: steering damper
« Reply #2 on: December 19, 2013, 09:38:41 AM »
You don't often hear of R65's having a steering damper.
Having the correct pre-load on the head bearings seems to provide enough damping for most.
Re: steering damper
« Reply #3 on: December 19, 2013, 12:40:46 PM »
I put one of these on a few years back. Bolts right up. "Steel Black Stabilizer"
http://www.pingelonline.com/steering_stabilizers.htm
« Last Edit: December 19, 2013, 12:42:22 PM by MrRiden »
Re: steering damper
« Reply #4 on: December 19, 2013, 10:50:41 PM »
Thanks,, there was one on  when I bought it and it has come apart, so I thought I should get another..it shows one in the parts micro.
Bill
Re: steering damper
« Reply #5 on: December 20, 2013, 12:06:56 AM »
Bill
I think it is officially known as a gee-gaw.  Possibly a farkle.  Especially if it is chrome.
Re: steering damper
« Reply #6 on: December 26, 2013, 12:23:54 AM »
My LS has one - and I believe it was standard equipment on this bike.
But other than that - I agree - they're probably not needed at all. However... if I had had the damper set to the stiff setting at the time of my elk strike, I may have been able to recover from the tank slapper that led me over the steep twenty-foot embankment. So I leave the LS damper on the stiff setting, and don't even notice the stiffness anymore.
Re: steering damper
« Reply #7 on: December 28, 2013, 08:49:55 PM »
That's a handy link - I may be shopping for a damper in  different lengths once I get my sidecar mounting sorted out.
Offline ShutterPilot
Re: steering damper
« Reply #8 on: January 22, 2014, 12:29:37 PM »
Sorry for the resurrection, but I'm also researching steering dampers for my R65.
Bike Bandit shows an OEM damper still available, part#373852, for $99.90.
Would this work?
Anyone know anything about these OEM dampers?
Re: steering damper
« Reply #9 on: January 22, 2014, 02:07:07 PM »
Hello !
The BMW classic shop shows that  31 42 1 238 221 is not order-able through them but not listed ans "ended" nor "unavailable". The other parts are available and priced as such . So you may be able to get the whole kit through a BMW dealer of some sort.
Offline DanMay
Re: steering damper
« Reply #10 on: February 02, 2014, 09:50:26 PM »
I just put one on my R65LS.  Here is what you need:
The damper that fits the R65 is the NHK ODM500.
http://www.fastfromthepast.com/servlet/the-1004/Steering-Damper-Stroke%3D85mm-/Detail
from BMW, you need:
31 42 1 237 285
07 11 9 931 684
07 11 9 932 850
07 11 9 931 019
07 12 9 906 196
I ordered the BMW bits from Max BMW.
