Author Topic: cleaning oily brake shoes. Possible ?  (Read 3984 times)
Re: cleaning oily brake shoes. Possible ?
« Reply #15 on: January 14, 2014, 08:45:26 AM »
Boiling the brake shoes is a dangerous indoor sport. Try it at your peril. I used my Coleman camp stove... outside.
Does that that 5L oil can have the bottom soldered in place? Uh Oh.
« Reply #16 on: January 16, 2014, 12:29:00 PM »
Experiment over for me, one of the shoes friction linings disbonded form the metal shoe .
So I need to get another set of rear brake shoes .
I don't think the hot water had anything to do with the disbonding, the other shoe is fine .
« Reply #17 on: January 16, 2014, 04:45:53 PM »
Go to a truck repair shop and ask where they get the shoes re lined. They will rebond or reline your shoes for wayyy less than BMW ask for a new set.
I used to work next door to such a shop and, at that time, never bought OEM brake shoes...
« Reply #18 on: January 16, 2014, 05:26:50 PM »
I've found EBC rear brake shoes for around $55US online free shippng .
Think I'll go with that .
Olliepup
« Reply #19 on: January 19, 2014, 02:30:09 PM »
I had grease on the front brake shoes of my '64 Lambretta scooter. Tried everything; soaking for a week in degreaser, soaking in lacquer thinner, mineral spirits, etc. No luck.
« Reply #20 on: January 19, 2014, 04:42:02 PM »
I did try using an ultrasonic cleaner about a year ago on a set of brake shoes, looked promising, but the sonic past of the cleaner quit and it was not worth the cost to repair it .
I was using Simple Green soap didn't foam up with use in the cleaner .
« Reply #21 on: January 22, 2014, 05:00:21 AM »
I had a leak from my final drive onto my brake shoes.  I cleaned them off with spirit and re- installed them.  They still work after a fashion i.e. they still bite.
And they will go through the MOT with them.  Perhaps they are not quite a powerful, but the I have twin disk Brembo setup on the front, where most of my braking is carried out.
« Last Edit: January 22, 2014, 05:00:53 AM by steve_hawkins »
« Reply #22 on: January 22, 2014, 05:28:14 AM »
I had a leak from my final drive onto my brake shoes.I cleaned them off with spirit and re- installed them.They still work after a fashion i.e. they still bite.
And they will go through the MOT with them.Perhaps they are not quite a powerful, but the I have twin disk Brembo setup on the front, where most of my braking is carried out.
I'm not a fan of an overly powerful rear brake so I'd probably do the same.
« Reply #23 on: January 23, 2014, 01:09:14 AM »
You know, when grease and oil dries out it gets really sticky! I figure that if I can remove most of the contaminants, the rest will eventually dry out and burn off.
I also don't see much use for the rear brake since it does only about 30% of the work. I guess for touring or sidecar duty, a powerful rear brake would come in handy, but for solo use, a disc is over-kill. The drum brakes have always been plenty for me.
I've cleaned up brake pads and shoes several times in the past and they worked fine afterwards. Don't recall what I used, may have been carb cleaner or laundry soap. Maybe Lacquer thinner. But afterwards they were light colored after a little sanding.
