Author Topic: Front brake performance improvement  (Read 3715 times)
jcsaintp
« on: December 18, 2013, 06:53:15 AM »
Have '84R65 with single disc, Brembo caliper. Current set-up functioning correctly with new fluid, ss line, good pads and rotor... properly bled.
Would like to increase stopping capability. Investigating finding components to add second caliper and rotor. OEM available but pricey! Any other suggestions?
Thanks,
Jeremy
Re: Front brake performance improvement
« Reply #1 on: December 18, 2013, 07:00:54 AM »
While you are at this, I would suggest replacing the rubber brakelines with braided stainless lines .
« Reply #2 on: December 18, 2013, 07:24:40 AM »
Already has a SS line as noted in original post.
Suggest starting a search online for good used components. May  not be easy or quick. Best chance would be to source a complete R65LS front end.
« Reply #3 on: December 18, 2013, 08:01:56 AM »
If he installs the second disc, he'll need three lines, one from the master cylinder to the splitter, then two from the splitter to each of the calipers .
Sounds like he has one line now from the master cylinder to the left caliper .
Another possible way to go, is to get a longer banjo bolt for the left caliper, then get a line made up to go over the fender to the right caliper .
Probably would need 90 degree banjo fittings on the ends of the new line .
If you were not aware of this, you most likely will need to replace the master cylinder as well, the 13 mm master cylinder used in the single disc, seems to be a bit on the weak side for dual discs .
Probably need to get a 15 mm master cylinder .
« Last Edit: December 18, 2013, 10:15:00 AM by Bob_Roller »
« Reply #4 on: December 18, 2013, 11:50:07 AM »
I can smell the burning credit card from here!  ;D
You did mention "good pads". How did you make this determination? What brand are they? Have you checked them for remaining pad thickness against the Bremo caliper's specifications?
EBC brake pads are very popular replacements.
Properly set up, single disc R65 front brakes can actually skid the front tire as I well know.
« Reply #5 on: December 18, 2013, 04:06:09 PM »
If you can get the bike to lock up the front tire there isn't any need for going beyond that... unless perhaps you are racing and need additional power to compensate for some fade caused by heat.
But if you wanna burn some cheese or time, you could try a couple things.
-find pads with the best friction rating you can, though keep in mind that some materials work better when hot and are really best for racing.
-if you put new pads on, do a thorough job cleaning your rotors, including in the drilled out holes.  No point in contaminating new pads with old grunge.
-cast iron rotor (will rust but should provide more bite than the stock stainless steel).
The smaller the MC bore, the more mechanical advantage you have on the caliper pistons.  The smaller bore will only become a problem if your brake lever is bottoming out on the handlebar, so it might be possible to go to a smaller bore for a single disc.
« Reply #6 on: December 19, 2013, 02:28:47 AM »
It has been my experience that often you trade power for progression.  I like progression.  But I do like enough power to pull her up quickly, when necessary.  Master cylinder sizes are matched for caliper/s for that very reason.
I am the very odd person that dropped his second disc for a single disc setup.  Its lighter and cheaper, and although I have ultimately lost a bit of power, its fine for a road bike.  And it has only improved with time.
But the point about pad material is a good one.  Some improvement might be gained here.  EBC make good pads as well.  But it will be difficult to measure any improvement and there will be a 'bedding in' period to muddy the water - so it is something that will take time.
If you are running a standard disc, as mentioned above, there are plenty of after market discs that should offer an improvement.  Again its down to materials used.
Has anyone considered mounting a bigger disc - in diameter?  You will have to mount an adapter plate for the caliper - to move it out.  But it should be achievable in theory.
Of course, if you have just jumped of some modern tackle, with a pair of 4/6 pot calipers on a discs the size of the whole wheel then you are going to be disappointed.  And I mean forever!
Rev. Light
« Reply #7 on: December 19, 2013, 02:46:57 AM »
Has anyone considered mounting a bigger disc - in diameter?You will have to mount an adapter plate for the caliper - to move it out.But it should be achievable in theory.
I have seen it, and I think on this forum (could be mistaken).
But then, it also was using a fork (and probably wheel) from another bike.
« Reply #8 on: December 19, 2013, 07:03:27 AM »
I replaced the OEM rotors on my '81 R65 6 years ago .
I now have EBC semi-floating steel rotors and EBC graphite pads .
Have I seen any noticeable improvement in braking, no .
The only improvement, is wet braking, which is greatly improved .
Which is a real benefit, seeing as I live in a desert !!!!! ;D ;D ;D
So, what I am trying to say, is that you can put a lot of money and effort into this, but the end result won't be much of an improvement over what you have now .
The one thing I do recommend, is replacing the OEM rubber lines with braided stainless aftermarket lines and aftermarket brake pads .
« Last Edit: December 19, 2013, 07:59:58 AM by Bob_Roller »
jcsaintp
« Reply #9 on: December 19, 2013, 07:32:19 AM »
Lots of good comments. Thank you!
Bought the bike from RePsycle BMW end March 2013. Pads reportidly new. Had a stainless line installed at that time. Have since put about 3,000 miles on the bike. Have been fortunate to find an excellent R and K bike mechanic locally who advised brakes working 'fine'. Had a wife who used to say she was 'fine'... but I digress.
I crashed about a month ago. In the process of repairing the bike, one of the folks I'm working with suggested I consider adding a second rotor given I'm 'party size' (i.e. weigh 225 pounds). Crash result of operator error, not insufficient brakes but situation could be different next time so looking into options.
Will keep on the prowl for needed components while working with local mechanic to make sure sure what I'm currently running in top form.
Component between my ears probably where greatest opportunity for improvemnt lay! David Hough's latest book, particularly section on aging riders (of which I'm one) has provided ample food for thought.
Thanks again,
Jeremy
« Last Edit: December 19, 2013, 07:43:05 AM by jcsaintp »
« Reply #10 on: December 19, 2013, 10:05:14 AM »
Jeremy, I've done business with RePsycle in the past and always found them to be good guys. Their statement that the disc pads were "fine" is their opinion as far as selling a motorcycle. The pads may even be OEMs, contaminated with brake fluid, or terribly glazed over. The term "caviet (sp?) emptor" comes to mind...
Try a pair of fresh EBC pads. Break them in as per the instructions and you'll be pleasently surprised. Plus, you'll save a ton of money. Keeping in mind that the duel disc setup adds a substantial amount of weight to the front end which will effect front suspension ande handling.
Last thought. Try tying back the front break lever and leaving it for a day or two. This is an old trick used to force up n' out remaining air bubbles.
« Last Edit: December 20, 2013, 08:02:52 AM by montmil »
Offline Matt Chapter
  • <insert witty remark here>
« Reply #11 on: December 19, 2013, 10:06:54 AM »
My rotor was warped beyond use a couple years ago.  Had the rotor rebuilt by spiegler, top notch.  Would highly recommend it if your rotor is out of spec.
Another thing that can be overlooked in the in the "stopping and going" department is tires.  Different manufacturers or even tire lines have different compounds.. more sticky = stops better, but also more sticky = wears faster.  Worn / old tires do not grip as well as new tires. (Ask me how I know!)
I'm of the opinion that the best investment for better stopping, as the OP mentioned, is some education and practice.  (once the system is sorted, at any rate) Take the basic MSF class if you haven't already, or take it again, or see if you can get into the advanced course.  Find some out of the way parking lot or road and practice controlled stops from different speed levels, in some different but common road conditions.
« Last Edit: December 19, 2013, 10:07:47 AM by mchapter »
'04 R1150 RT ~41000 miles
« Reply #12 on: December 19, 2013, 01:16:00 PM »
Well finally my Latin background is useful!  it's Caveat (and for more than you wanted, a 3rd person singular present active subjunctive)
Monte, does EBC make both sintered and organic pads?  I briefly had a set of BraKing sintered metallic pads on my bike and they had more bite than the current EBC organics.  The BraKings did not have the right backing plate, and I wasn't happy with the way grinding them down turned out, which is why I went to the EBCs.
« Reply #13 on: December 19, 2013, 05:27:29 PM »
I rock the EBC organic disc pads on both my R65s. They play nicely with the OEM brake discs and offer outstanding braking performance... IMO.
Luca, I could have looked up the correct Latin spelling but right now I'm down on the Texas Coastal Bend, Port Aransas, enjoying a condo on the Gulf of Mexico, excellent fresh seafood, 75 plus degrees and sunny. Plus multiple cold cervesas.
Off to Austin, Texas, tomorrow to hook up with the grandkids.
Screwing with this PC I found in the condo. I miss my Mac.
« Last Edit: December 19, 2013, 05:35:20 PM by montmil »
« Reply #14 on: December 19, 2013, 05:36:30 PM »
The bike is old, and it's braking performance will NEVER be on par with the current market.  This is something to keep in mind while riding!
That said - the R65's had GREATLY improved brakes and front ends over the Type 247.
They do need regular maintenance, which I was never a fan of, apparently.  As you would see in the picture below, of when I rebuilt my brake system.
In other words, you may want to consider opening your caliper and see what it looks like.
http://www.pbase.com/tomfarr/r65_brakes
