Author Topic: removing/installing diaphragms?  (Read 5420 times)
« on: November 27, 2013, 03:50:53 PM »
I bought the carb kit that includes the diaphragms. I read snowbum's article but am still not sure how to get the old diaphragm off the slide, or the new one on. I tried simply pulling it off and only succeeded on tearing the rubber.
What's the trick?  :(
Re: removing/installing diaphragms?
« Reply #1 on: November 27, 2013, 04:19:09 PM »
I don't have the diaphragms like you have .
But from the post here from members that have, the plastic ring that secures the diaphragm to the slide needs to be heated up to get the diaphragm off .
I'm not real sure, but the plastic rings are difficult to get, the whole assembly, the slide and diaphragm and ring come already put together .
So be gentle in your removal process, or better yet, wait until someone with some experience with this posts about it .
« Last Edit: November 27, 2013, 04:20:04 PM by Bob_Roller »
« Reply #2 on: November 27, 2013, 04:51:37 PM »
I bet you've the flat topped carbs.
The diaphragms are said to be non removable and have to be changed with the whole piston which is very expensive. I know some of us had succeeded in removing the plastic band, exchanging the diaphragm and re assembled back the plastic ring without breaking anything. I also know some people whid did destroy the rubber and the plastic band forcing them to spend $$$ at the dealer...
So wait for the expert advice from successful people.... And experience caution and delicacy.
« Reply #3 on: November 27, 2013, 05:02:17 PM »
Can't recall how I handled mine, but can you pull those down towards the needle, instead of trying to lift them off the top?
« Reply #4 on: November 27, 2013, 06:26:18 PM »
 :'( I'm not feeling real encouraged here. I just looked at the parts fiche- $90 each!  :o
Help!!
« Reply #5 on: November 27, 2013, 07:11:56 PM »
Do you have flat topped carbs?
« Reply #6 on: November 27, 2013, 07:23:52 PM »
Flat topped carbs, yeah.
I've done some more reading, and its said to put the whole slide in hot/boiling water and the nylons ring will "slip off".
I tried a heat lamp and the nylon ring loosened up enough to spin freely, but doesn't seem close to coming off. I'll try boiling water sometime in the next couple of days.
« Reply #7 on: November 27, 2013, 07:26:22 PM »
Snowbum strongly advises against buying diaphragms directly from Bing. The Bing website has a category for BMW parts... Has anyone tried them?
« Reply #8 on: November 27, 2013, 08:48:51 PM »
Original Bing parts are all I've ever used .
There have been reports from members here, that the aftermarket diaphragms are too thick and inflexible for motorcycle use and cause poor running .
This is one time I strongly disagree with Snowbum's reccomendations .
« Reply #9 on: November 27, 2013, 09:06:02 PM »
Thanks Bob. Have you compared prices?
Offline Kookaburra
« Reply #10 on: November 28, 2013, 11:29:31 AM »
Would advise against using Stromberg replacement diaphrams. They fit and are Ok as an emergency fix but they are thicker and change the way the bike runs.
« Reply #11 on: November 28, 2013, 02:45:32 PM »
I always bought my diaphragms from Bing.  I was warned away from the Strombergs by older, more experienced airhead owners.
It was a godsend once Bing started selling the diaphragms and plastic rings separately from the slide.
« Reply #12 on: November 29, 2013, 02:09:33 AM »
I have replaced mine on my flat-tops, but I do not recall there being much of a knack.  Or at least I cannot remember that I did anything particularly special....I certainly did not buy the whole unit - So I would not go down that route.
I probably carefully levered them off.  Assuming the old one is definitely toast.
Orientation is critical
Good luck.
Rev Light
« Last Edit: November 29, 2013, 02:11:23 AM by steve_hawkins »
« Reply #13 on: November 29, 2013, 04:45:18 AM »
Yep - if you are dealing with flat-top carbs, there is the plastic ring to deal with in R/R the diaphragms.
They snap off easily enough (just work a small screwdriver under them), and can be reused as long as they are within tolerance.  (If they don't keep things sealed, they are out of spec...)
With new plastic rings I usually warmed them in boiling water for a few minutes before snapping them in place.
The diaphragms will have two locating tabs.  One on the ID and one on the OD.  They both have slots in the slide/carb body to be matched up.  This ensures that the slide is in the carb correctly.
« Last Edit: November 29, 2013, 04:52:27 AM by Rob_Valdez_79_R65 »
« Reply #14 on: November 29, 2013, 06:13:50 AM »
Thanks guys, seems straightforward enough. I found another thread where the guy used a light to heat the ring, per a Bing tech's suggestion.
http://www.bmwmoa.org/forum/showthread.php?52288-1978-R100-7-Flat-top-Carburetor-Rebuild
Snowbum's site has a ton of great information, but reading it can lead to a lot of over-thinking. For me, at least.  :P
