Author Topic: VDO clock voltmeter  (Read 3852 times)
airhead27
VDO clock voltmeter
« on: January 25, 2012, 07:23:47 PM »
Does anybody know if the VDO guages clock and voltmeter fit  correctly into the aftermarket pods for an r65 and is the wiring connection to the VDO clock and voltmeter  the same as the original bmw clock and voltmeter.
Thanks, Brian
airhead27
Re: VDO clock voltmeter
« Reply #1 on: January 28, 2012, 09:38:36 PM »
If anyone is interested I picked up the pods at Larry "Stoner" Stonestreet
Stoner's Beemer Stash 60$ a pod now I have to track down clock voltmeter and wiring harness
airhead27
« Reply #2 on: February 24, 2012, 08:27:22 AM »
These are the additional parts I needed to get the accessory guages working. The wiring harness needs minor soldering but is straight forward.
Will send a picture/ update when completed.
Happy Trails
Brian
ordered these from Jegs.com
VDO #918-370-155
Vision Clock
2-1/16"
Analog
VDO #918-332-103
Vision Voltmeter
8-16 volts
$29.99 Ships Today
These are the parts from motobins.
WIRING HARNESS FOR ADDITIONAL CLOCK & VOLTMETER 1974-84      79870      1      £33.00
INSTRUMENT SUPPORT PLATE FOR 87011/87111 R45/65 1978-1984 RIGHT EACH      87117      1      £4.00
INSTRUMENT SUPPORT PLATE FOR 87011/87111 R45/65 1978-1984 LEFT EACH      87116      1      £4.00
airhead27
« Reply #3 on: March 01, 2012, 12:54:18 AM »
unfortunately did not work out as well as I would like. I did not need the additional wiring harness from motobins; it would be just as easy to buy some wire and make a home made wiring harness . the  vdo gauges fit the pods in diameter  and was able to wire the gauges o.k. but will need some type of modification so that the gauges  will be secure  in the pods.
