Author Topic: 65LS starting  (Read 3093 times)
wmsoller
65LS starting
« on: September 09, 2013, 09:44:47 PM »
So..Putting together this LS I got in pieces a while back and having trouble with starting. I turn the key and hear the starter solenoid engage, but when I press the starter button, nothing....everything seems to check out but not certain where it went wrong...
Re: 65LS starting
« Reply #1 on: September 10, 2013, 12:23:54 AM »
Do you have your instrument panel setup ?   Do you see the neutral indicator "on" ?  If the neutral switch isn't activated, the starter relay won't activate - UNLESS- you pull in the clutch lever instead to start the bike.   So, either clutch switch must be installed and active (it grounds a pin on the starter relay (can't recall which one at this instant) when active... or the neutral switch ahs to be grounded - which would indicate gearbox is in neutral ordinarily, but if you've got the gearbox disconnected or you are SURE it is in neutral you could "jumper" the 2 neutral switch wires.
Maybe check the wiring to see that these switches are both wired up correctly and the neutral light is happy?
Re: 65LS starting
« Reply #2 on: September 10, 2013, 08:17:29 AM »
When you turn the key to the 'ON' position, the starter solenoid engages without touching the start switch ???
Re: 65LS starting
« Reply #3 on: September 10, 2013, 08:36:29 AM »
... I turn the key and hear the starter solenoid engage...
That should not happen! Got to be some wiring issues -beginning with the ignition switch harness and wires that need to be traced and confirmed as correct.
Re: 65LS starting
« Reply #4 on: September 10, 2013, 12:15:34 PM »
Hmm you guys are right - I missed that part last night - definitely wiring issues right there!  But also, please do tell us about your dashboard lights, what comes one/what doesn't (asusming they are hooked up, which I would recommend doing as it will help diagnose soem things)
wmsoller
Re: 65LS starting
« Reply #5 on: September 10, 2013, 01:18:29 PM »
Thanks, guys. Let me jump into this tonight and see what I can figure out.
Re: 65LS starting
« Reply #6 on: September 10, 2013, 03:02:00 PM »
Before you get too far with this, with the fuel tank off, turn the key to the 'ON' position and see if the noise you hear is a relay under the tank, not the starter .
Re: 65LS starting
« Reply #7 on: September 10, 2013, 03:34:06 PM »
Good point, Bob R.  Still, what relay might "click" when the ignition is turned "ON"? Still thinking there's a wiring mix up that needs to be sorted.
William, is your battery in top condition and well charged?
Re: 65LS starting
« Reply #8 on: September 10, 2013, 04:59:11 PM »
Headlight relay will click on with the key on US bikes - and click off again (supposed to anyway) when the starter relay is engaged..
wmsoller
Re: 65LS starting
« Reply #9 on: September 25, 2013, 03:09:51 PM »
Well..I think I got it sorted out..except..
Without the ignition key inserted, should the neutral light turn on when I flip the ignition switch or should I be able to turn over the starter...I think I know the answer.
Re: 65LS starting
« Reply #10 on: September 25, 2013, 03:43:58 PM »
Unless the ignition switch is in the 'PARK' position, with the  key removed you should not be able to turn on anything electrical on the bike .
In the 'Park' position, the tail light and the small lightbulb under the headlight will come on .
Re: 65LS starting
« Reply #11 on: September 25, 2013, 11:10:26 PM »
And you can turn the switch off with any BMW key. The lock is not keyed in this position  ;D
wmsoller
Re: 65LS starting
« Reply #12 on: September 28, 2013, 07:09:51 PM »
I'm thinking I have the ignition switch incorrectly wired...as I can now start the bike without the key turned on. The start switch on the right hand side always provides power when flipped on...regardless of the use of a key.
Re: 65LS starting
« Reply #13 on: September 29, 2013, 03:21:49 AM »
This is how the ignition switch should be wired.
RT = Red
Gr = Grey
GN = Green
GE\WS = yellow\white
GN\VI = Green\ Violet
If the engine actually starts without the key then I think I would make sure to keep the kill switch in the off position or disconnect the battery as the otherwise the ignition system may continously draw current and flatten the battery.
« Last Edit: September 29, 2013, 03:31:39 AM by bhodgson »
Re: 65LS starting
« Reply #14 on: September 29, 2013, 01:12:28 PM »
I tried this on all three of my R65's, if you don't have the correct key, you cannot move the ignition switch to the 'PARK' position .
This may work on European bikes, but not on North American version bikes .
