Author Topic: Removing piston from caliper  (Read 918 times)
erod1
« on: August 18, 2013, 04:31:12 PM »
So I took apart the brembo caliper on my 86 r65 to rebuild the leaky caliper. But I cannot figure out how to remove the piston. I have tried to pull on the ceramic part of the piston and pieces just chip off. Any help will be appreciated .
Re: Removing piston from caliper
« Reply #1 on: August 18, 2013, 04:40:54 PM »
Compressed air is about the only way to get it removed once the caliper is removed from the bike .
If you do it, place the caliper inside a large plastic bag with some old shop rags to keep it from going too far when it does come out .
Fluid will go everywhere when you do this, so be prepared for it !!!!!
erod1
« Reply #2 on: August 18, 2013, 05:38:18 PM »
Thanks. While having diner I thought about compressed air. They came out. Now to order parts.
