Author Topic: Neutral switch leak  (Read 890 times)
quixotic
Neutral switch leak
« on: July 01, 2013, 06:57:14 PM »
Has anyone tried using Hi-temp silicone seal on this?  Or is the gear oil under pressure and just blows through?
Re: Neutral switch leak
« Reply #1 on: July 01, 2013, 06:58:35 PM »
The oil leak is through the switch itself, not around the threads .
The oil isn't under any pressure, there is a vent for the transmission, it's through the small hole drilled through the negative battery cable bolt at the speedometer drive cable area .
« Last Edit: July 01, 2013, 07:00:40 PM by Bob_Roller »
« Reply #2 on: July 01, 2013, 08:40:24 PM »
The plastic internal body of the switch is generally the part that cracks and develops a leak.  There is an all-metal alternative, but I don't recall the brand at the moment.  If there is a leak on the thread area, it would indicate that a new crush washer is needed-
« Reply #3 on: July 02, 2013, 09:06:07 AM »
Check Motobins for their R65 repop neutral switch. It's Italian made and mostly brass. Installed one on my '81 R65.
A more economical price than BMW OEM, no dribbles for years now and Royal Air Mail to Texas was less pricey than buying "local".
