Author Topic: tool kit  (Read 1278 times)
tool kit
« on: May 08, 2013, 03:01:21 PM »
Hello !
When I bought my new '82 R65 (in April 84... the bike sat for a couple of years in the showroom) I got the tool kit.
But as far as I can remember, there where no tire irons in it.
Also, the RealOem site shows a tube socket #21 which I do not have and I wonder what it is used for.
Could you please tell me if, on bikes of the same era, the irons where standard or an extra, and what is the tube socket and what's use it has .
Many thanks in advance for your answer ;-)
Re: tool kit
« Reply #1 on: May 08, 2013, 03:08:53 PM »
My tool kit did not come with #'s 19 and 21 .
I know one of the tube sockets, is for spark plug removal, when you place item # 17 in the round hole, you can remove the plugs with a tap of one of the wrenches if you can't loosen it by hand .
Re: tool kit
« Reply #2 on: May 08, 2013, 03:11:26 PM »
My tool kit does not have tire irons or the tube socket #21
Offline k_enn
Re: tool kit
« Reply #3 on: May 08, 2013, 03:12:05 PM »
^ x3  (1982 R65 US purchased in 1982)
« Last Edit: May 09, 2013, 10:33:47 AM by k_enn »
k_enn
original owner of:
?1982 R65
? 2014 K1300S
RSMike
Re: tool kit
« Reply #4 on: May 09, 2013, 02:08:41 AM »
Looks like Motobins sells two complete kits, an original BMW one and their own priced at UK138 & UK83 respectively. They both have the tyre irons, not sure about the other piece though. TBH the Motobins own kit looks better.
So seems like good value included with your original R65 purchase!
bruce_launceston
Re: tool kit
« Reply #5 on: May 09, 2013, 03:23:39 AM »
No 21 seems to have 2 pins so would presumably undo the ignition switch bezel.
I just use my leatherman needle-nosed pliers.
My '84 didn't come with #21 or any tyre levers although I added my own levers.
I don't keep them in the tool roll, they live in a sleeve of pushbike inner tube in the bottom of the tool tray.
« Last Edit: May 09, 2013, 03:24:02 AM by bruce_launceston »
Re: tool kit
« Reply #6 on: May 09, 2013, 05:25:52 AM »
I think the bottom line is R65 tool kits were never quite as comprehensive as the earlier bikes.
RSMike
Re: tool kit
« Reply #7 on: May 09, 2013, 01:44:43 PM »
Hey George, you can compare yours with this one that is for sale by Dan in Ontario:
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1367956501
Looks like this does not have tire irons or the other funny round piece either.
Re: tool kit
« Reply #8 on: May 09, 2013, 02:10:46 PM »
Yes, exactly the same ! Even the yellow trim is identical !
I bet it came from an '82 bike ...
Offline Speyman
Re: tool kit
« Reply #9 on: May 10, 2013, 05:50:26 PM »
Mine is identical to the photos; from a '81 US delivery bike. I've added substantial tire irons plus a feeler gauge . . . . Also have an aluminum Zefal tire pump for the top frame tube.
