Author Topic: valve job questions and THANKS!  (Read 3691 times)
Chris_in_BC
Re: valve job questions and THANKS!
« Reply #15 on: July 30, 2007, 03:22:03 PM »
Bob, Our '81 R65 got the exhaust valves replaced at 100K so I guess engines vary. Also, we don't have the temperatures that you normally have to ride in down your way.
But I thought BMW had the problem solved by '83, but maybe it wasn't until '84, which was why I was wondering about jep and his '83.
Jep, Just make sure you get the valve seats (if required) replaced by someone experienced in BMW engines. Not just the average machine shop. I made a mistake years back having a local guy do my seats. I told him the recommended temperature the heads have to be heated too, but he said he never went that hot for all the Harley's he had worked on ( I should have run then  :-[ ) Bottom line the head wasn't hot enough , so valve seat cocked going in and buggered up the head. Had to have special machine services to custom make a larger OD valve seat and custom machine a larger clean hole.  My idea of saving a few dollars sure failed that time!
« Reply #16 on: July 30, 2007, 03:41:07 PM »
From what I have read BMW finally got it right in the '85 and later engines.
« Reply #17 on: July 31, 2007, 10:51:17 AM »
I also heard that it was '85 or '86 that the valve seats issue was resolved.
I've generally made it a point in the past to look for '86 model year bikes
to be certain.
« Reply #18 on: July 31, 2007, 01:42:35 PM »
What year did BMW finally get the early '80's valve seat issue solved ? My '81 had the valves go bad by 45,000 miles, the seats looked like they were almost new, and the valve face was 2/3's gone.
Bob, according to Snowbum (also Bob) the year was around 1985:
http://bmwmotorcycletech.info/valves.htm
45,000?  Oh no.  I'm at a bit over 50,000.  I wonder if my baby will let me pay off the freaking tranny rebuild and clutch parts before I start seeing valve deformation.
