Author Topic: quickie - snowflakes on R65LS ?  (Read 2475 times)
bruce_launceston
Re: quickie - snowflakes on R65LS ?
« Reply #15 on: March 21, 2013, 06:26:49 AM »
I think powdercoating may be less flexible than a good 2-pack automotive paint. I had mine done professionally. Lots of people get wheels powdercoated but the composite wheel with its different alloys may be a challenge.
« Last Edit: March 21, 2013, 06:28:05 AM by bruce_launceston »
jgp1854
« Reply #16 on: March 21, 2013, 08:26:59 AM »
Sorry to barge in but do have a question?  Were the OEM wheels/tires on the 82 R65LS TUBED OR TUBELESS?  I currently run mine with tubes, only because it had tubes when I took ownership.
thanks
jgp
« Reply #17 on: March 21, 2013, 08:50:04 AM »
The bikes came with tubes installed .
Seems to be a question about it, some claim that the wheel has the proper taper to keep a tubeless tireon, others don't think it's a good idea .
My '84 LS came with no tubes installed, the tires were worn out when I got the bike .
Personally, I'd run with tubes installed .
Offline Julio A.
« Reply #18 on: March 21, 2013, 09:33:37 AM »
Looking at old brochures of tue R65, the rims were designed with a unique feature to prevent the tire carcass from slipping off during rapid deflation of the tires while running. By design, the snowflake still uses a tube. The anti-slip feature just so happens to permit the use of tubeless tires.
« Last Edit: March 21, 2013, 09:35:15 AM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #19 on: March 21, 2013, 11:12:28 PM »
There's definitely a bit of controversy on the 'tube' issue. I've been running mine tubeless and don't see a problem with it - they do have the bead-retaining ridge all tubeless rims have. What's the difference?
Offline Julio A.
« Reply #20 on: March 22, 2013, 08:21:15 AM »
Hey, just as long as it works! I run a tubed tire at the back and a tubeless one at front. The local shop ran out of properly sized pairs with the same thread.  ;D
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
