Author Topic: She puzzles me !  (Read 2587 times)
Re: She puzzles me !
« Reply #15 on: March 06, 2013, 02:42:11 PM »
When doing a compression test, pull the carbs loose from the head's intake stubs. Otherwise, you'll need remove the air filter 'elbows' and  some way hold the CV slide and butterfly fully open to get a proper reading. Carbs on, slides down and butterfly closed restrict air into the combustion chamber and provide incorrect CR readings.
« Reply #16 on: March 07, 2013, 12:34:51 AM »
Yes, done that... My finger still smell gasoline.
I just checked the maint. manual.
10.0 is good 10.5 is excellent.... So I've to find something else... (and check valve clearance)
« Last Edit: March 07, 2013, 01:18:01 AM by georgesgiralt »
« Reply #17 on: March 07, 2013, 07:09:51 AM »
Hello !
We have an intermittent here...
I had a date for lunch. And was mighty late. So I jumped on the bike and twisted the grip hard in order to save one of my eyes... from her....
Guess what ? The bike was an angel. She ran as fast as I dare go and had no trouble at all.
So this offer me new opportunities. Maybe something is moving and clogging a passageway in the carb or I've a bad connection on the ignition system....
I'll have to check !
Online Bob_Roller
« Reply #18 on: March 07, 2013, 09:22:47 AM »
There have been some issues with the ignition centrifugal  advance mechanism in the 'bean can' sticking .
Again, just another guess .
« Reply #19 on: March 07, 2013, 01:02:16 PM »
Well,
again, I checked the ignition... (by the way, I've found that the gasket INTO the can on the axe 'which is concealed on the bottom so is not replaceable was leaking...)  But every time I check, the advance and ignition run fine. This does not mean that it is *always* running fine...
« Reply #20 on: March 07, 2013, 10:54:18 PM »
How new is the ignition coil? This is electronic ignition? Right?
How about the ICU heat sink? Is it seated well, with a thin layer of heat sink paste?
« Reply #21 on: March 08, 2013, 01:09:24 AM »
The coil is new (changed last may for the new Bosch). the ICU is "in order" I checked it at the same time. This ignition system fires well and is tuned correctly (I've used my timing light two days ago...)
But some wires on the loom are not so good : the voltage regulator sometimes does not work, bad contacts. So I wonder if maybe all this could be an electrical problem, in fact....
This week end, I've to go away to see my mother in law  :'( so all tests will be postponed to next week which is a very busy week...
« Reply #22 on: March 08, 2013, 05:46:34 PM »
Ive heard more than a few times that most carb problems are electrical.
I have a little honda nighthawk project ive been working on and the darn thing wouldnt run off idle worth a darn because the battery was shot. After 4k ( it goes to 10k ) she was good because the alternator could keep up with the increasing demand on the ignition system.  If your charging system is suspect, you might not be getting enough juice to make a good spark at bigher rpms. Like Monte said, you dont get full compression with partial throttle. As you open the throttle the compression increases, and increased compression requires a stronger spark.
Anywho, one thjng you could do to help determine if fuel starvation is the issue is get the bike going as fast as she will allow, simultaneously pull the clutch and cut the engine, and read the plugs right on the side of the road.
« Reply #23 on: March 09, 2013, 07:24:10 PM »
Any excuse to ride full throttle.
Offline Matt Chapter
  • <insert witty remark here>
« Reply #24 on: March 11, 2013, 10:08:07 AM »
..will eventually get you a broken valve spring.   :-[
'04 R1150 RT ~41000 miles
