Author Topic: Brembo Vs. ATE Front Brake Caliper (R65 Only)  (Read 12424 times)
Offline Julio A.
« on: July 29, 2011, 05:04:07 AM »
In Line of the lack of accurate information regarding the difference on ATE and Brembo calipers made for the R65, I decided to make my own informative thread about the difference between the two manufacturers.
Before I anything else, I would like to point out that these information on pertain to the Calipers found on Dual shock R65 only. Monoshock R65's use a different caliper as well as other models(R100 etc...) interchangeability between these calipers are unknown.
The Shell:
The Caliper Shells are very different in outer design yet very similar in regard to internal function.
*Different outer design
*Different Cutaway near piston(for piston shroud)
*The o-ring that seals the the two halves are the same
*Piston Seals are the same
(ATE Shell on Top, Brembo Shell bottom)
Piston:
The piston between the two calipers are almost the same, except for the metallurgy used by the two brands. ATE uses a chrome coating that tends to rust off while Brembo uses a more superior metal that does not rust and is of the color grey.
*Piston Diameter between two manufacturers are the same(36mm)
*ATE Pistons are taller by a little below 1mm
(Brembo Piston Left, ATE Piston Right)
Piston Shroud:
ATE uses a metal ring to secure the Piston shroud into the Caliper, unfortunately, the metal ring is a good possible source of rust that will eventually destroy the brake pads, causing break squeal and slowly kill the pistons without regular maintenance.
Brembo on the other hand, does not use any clamps or retainers at all.
The Brembo Piston Shroud has a lip that secures itself to the Caliper Shell.
*Brembo Shrouds have a larger outer Diameter
ATE on Left, Brembo on Right
Brembo Top, ATE bottom
Brake Pads:
Both brake pads have the same contact surface area. Different top portions to accommodate the different spring setups between the two calipers.
(Brembo Left, ATE on Right)
*As far as I can certainly tell, A Caliper piston from a dual piston Brembo Caliper taken from an R100 is larger (Diameter = 38mm) as well as the piston shroud inner diameter.
Comments as corrections are welcome.  ;D
« Last Edit: July 29, 2011, 10:58:15 AM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Offline rkjjeep
Re: Brembo Vs. ATE Front Brake Caliper (R65 Only)
« Reply #1 on: October 13, 2024, 06:02:36 PM »
I know this is a very old thread.  My question is- Are the Brembo and ATE 36mm caliper seals the same as stated above?  Will the ATE dust seals fit the Brembo pistons?  I am trying to restore ATE calipers without mortgaging the house.
« Reply #2 on: October 13, 2024, 07:34:11 PM »
The piston seals are the same .The dust seals are not the same .
I can't link to the site, euromoto electric has complete kit to replace all the parts for ATE calipers for about $30 .
If you haven't had the calipers apart yet, you may find them rusted and may not be able to be reused .
Offline rkjjeep
« Reply #3 on: October 14, 2024, 07:48:41 AM »
Thank you for the reply.  I have rebuilt dozens of both but I was never aware that the piston seals were the same.  I have great pistons and housings with good bores and the seals in the EME kits just aren't working out. The seals are a little loose in the groove in the caliper.  They seal the fluid properly but I have so much retraction that the lever travel is all used up just getting the pads to the rotor.
Offline Loan Rider
« Reply #4 on: June 01, 2026, 03:11:38 AM »
For anyone who is curious, this photo shows what the ATE calipers fitted to my (twin shock, twin disc) 1979 R65 look like when dismantled and cleaned as part of my resurrection of the bike.
For anyone in UK, overhaul kits are available from Motorworks https://www.motorworks.co.uk/brake-caliper-repair-kit-bra54809-2.html
Note the very small square section O ring that goes between the two caliper halves.
I couldn't find an official torque setting for the bolts that hold the caliper halves together, so used 30 lbft with thread lock.
